SIYI MK15 Camera IP67 Camera B
  • SKU: MBS-SIYI-02-02
  • GTIN: 0658917500726
  • HAN: IP67CAM-MK15-B
  • Category: Accesoires
  • IP67
  • Dual Spotlight
  • LED Angle: 120
  • 1080p @50fps
  • Ethernet Port
  • IP Adress: 192.168.144.26
The MK15 Camera from SIYI has the protection class IP67 and can therefore be used in many ways. In addition, it has an Ethernet connection and dual spotlights.
  • Image Sensor: 1/2,9
  • FOV: 105
  • Resolution: 720p (1280*720) @30fps, 1080p @50fps
  • Searchlights Power Consuption: 8W
  • Searchlights Liminous Flux: 1W / 120 - 140lm
  • LED type: transparent
  • LED Angle: 120°
  • Cable length: 60cm
  • Dimensions: 30 x 115 x 48 mm (excl. cable)
  • Weight: 91g
  • Working Temperature: -10 ~ 50°C
  • SIYI MK15 Camera IP67
Shipping weight: 0,60 kg
Item weight: 0,50 kg
€ 64,99
