SIYI MK32 Handheld Ground Station
  • SKU: MBS-SIYI-19
  • GTIN: 0658917501051
  • HAN: MK32
  • Category: Accesoires
  • 7" Monitor (high Definition and high brightness)
  • Qualcomm 8-Core CPU
  • 4G RAM and 64G ROM
  • Dual-Operator-Feature
  • Range: ~15km
The MK32 Ground Station has a built-in 7" monitor with high resolution and sharpness. With max 1000nit, information and images from the ground control software are displayed on the screen.
The MK32's connection is based on SIYI's independent wireless HD image transmission technology, an all-in-one connection. The technology has the feature that the transmission can automatically adapt to the frequency band with the fewest interfaces. In addition, the MK32 is equipped with an 8-core Qualcomm CPU, which can smoothly decode 1080p @60fps video streams in H.264 or H.265 format. Ground Station's Android system has been upgraded to 4G RAM and 64G ROM.
The dual operator function (multiple connection) allows two MK32 Ground Stations to control the same flight unit. One controls the drone's attitude and the other controls the payload, such as gimbal cameras or pods. In this mode, two ground stations can capture images, both from the same camera and from different ones.
For long-distance flights, the remote control relay function is designed. One MK32 is able to relay the control of another over the same flight unit, allowing twice the range to be achieved. This function can be used for UAV surveillance, UAV remote delivery, etc.
Overall
  • Max. Transmission Range: 15km (unobstructed, free of interface)
  • Channels: 16 physical channels, 16 communication channels
  • Datalink compatible flight Controllers: Pixhawk / APM based flight Controllers or any flight Controllers with UART datalink output
  • Image Transmission compatible Android GCS: QGroundControl | SIYI FPV
  • Image Transmission compatible Windows GCS: QGroundControl
Ground Station
  • Monitor: 7" High Definition and high brightness LCD Touchscreen
  • System: Android 9.0 OS, 4G RAM & 64G ROM
  • Dimension (antenna overlapped): 308 x 148 x 72 mm
  • Weight: 1440g
  • Battery Capacity & Type: 10200mAh 7.4V 2S-Li-ion, 75.48 Wh
  • Fast Charging Protocol: PD 30W
  • Charging Time: 3,5 h (30W PD Charging)
  • Battery Life: 10 h
  • Video Output: Standard HDMI
  • External Device: USB-A
  • MIC Input: Top Audio Port
  • Charging: Type-C
  • Firmware Upgrade: Type-C
  • File Transfer: Type-C / USB-A
  • 4G Cellular Network: SIM Card Slot
  • External Storage: TF Card Slot / USB-A
  • Communication: LAN (Ethernet)
  • RC Input / Output: Bottom Audio Port
  • Waterproof: IP4X
  • Working Temperature: -10 to 50°C
  • SIYI MK32 Ground Station + MK32 Air
Shipping weight: 2,00 kg
Item weight: 1,44 kg
€ 819,95
