Holybro X650 ARF Kit
  • SKU: MBS-DR-64
  • GTIN: 0658917504823
  • HAN: 30179
  • Category: Drones
  • X650 V2 carbon chassis kit with folding arms
  • MN4014 KV330 T motor
  • Flight time: approximately 30 minutes
The Holybro X650 ARF Kit is an almost ready-to-fly multirotor set designed for developers, research institutions, and demanding hobby pilots. Its robust carbon frame with foldable aluminum arms provides excellent stability while remaining compact for transport. Motors, ESCs, LEDs, and power wiring are pre-installed, allowing a fast, solder-free assembly. The spacious mounting area offers ample room for additional sensors, cameras, or companion computers such as the Raspberry Pi or NVIDIA Jetson.
Technical Data
  • Frame
    • Wheelbase: 650 mm
    • Motor mounting pattern: 16–25 mm
    • Top & bottom plates: Carbon, 160 × 160 mm, 2 mm thick
    • Arms: 20 mm carbon tubes with foldable aluminum joints
    • Landing gear: 16 mm and 10 mm carbon tubes with reinforced plastic T-connectors
    • Top/battery plate: 120 × 128 mm carbon
    • Payload platform: Mounting options for GPS or mini-computers
    • Dual-rail system: 2 × Ø 10 mm, 320 mm length each
    • Battery holder: Two pads + straps
  • Electronics & Propulsion
    • 4 × Motors: T-Motor MN4014 KV330
    • 4 × ESCs: Tekko32 F4 45 A
    • 4 × LED strips: NeoPixel WS2812
    • Propellers: 4 × Gemfan 1555 (carbon)
    • PDB: XT60 battery input, XT30 outputs for ESCs and accessories
  • Flight Data & Payload
    • Flight time: approx. 30 min hover with 6S 10,000 mAh battery (without payload)
    • Kit weight without battery: approx. 2,000 g
    • Max. payload:
      • approx. 4.3 kg (without battery)
      • approx. 3.5 kg (with 5,200 mAh battery)
      • approx. 3.1 kg (with 10,000 mAh battery)
    • Max. takeoff weight: approx. 6,300 g at 70% throttle
    • Recommended battery: 6S LiPo, 5,000–12,000 mAh, XT60 connector (not included)
Scope of Delivery
  • X650 V2 carbon frame kit with foldable arms
  • 4 × T-Motor MN4014 KV330
  • 4 × Tekko32 F4 45 A ESC
  • 4 × Gemfan 1555 carbon propellers
  • 4 × NeoPixel WS2812 LED strips
  • PDB with XT60/XT30 connectors
  • Battery straps & assembly tools
Shipping weight: 3,00 kg
Item weight: 2,00 kg
€ 859,95
Docs MYBOTSHOP documentation
