Holybro H-RTK Unicore UM982 (Dual Antenna)
  • high precision position data
  • GPS-Heading
  • based on Unicore UM982 NMEA GNSS module
  • magnetometer, LED, safety switch
Holybro's UM982 Dual Antenna RTK GPS is capable of providing highly accurate position data and producing non-magnetometric moving baseline yaw determinations for autopilots using only one GPS module. Using this GPS as a yaw source eliminates magnetic interference as well as other sources of interference. Even if the GPS units do not receive RTCM data this function takes place. This RTK is based on the Unicore UM982 NMEA GNSS module and supports RTK position adjustment for centimeter accuracy, GPS/GLONASS, Beidou, Galileo and QZSS global positioning systems.
Note: Recommended to use the H-RTK F9P Base or F9P Helical as the base station. The setup in Mission Planner and QGroundControl is simple. MP and QGC currently cannot automatically configure the UM982 as a base station, additional manual setup is required.
  • Product: UM982
  • Application: Rover, Moving Baseline Rover, Base Station (Recommended using H-RTK F9P-Base as base Station)
  • Compass: IST9310
  • GNSS: BDS B1I/B2I/B3I, GPS L1C/A/L2P (Y)/L2C/L5, GLONASS L1/L2, Galileo E1/E5a/E5b, QZSS L1/L2/L5
  • Antennas Peak Gain (MAX): 2dBi
  • LNA Gain (typical): 33+/-2dB
  • Time-TO-First Fix: Cold start: ≤ 30s | Hot start: ≤ 5s
  • RTK-SurveyIn-Time: ≤5 minutes @2.0mCEP
  • Data und Update rate: 20Hz Positioning & Heading | 20Hz Raw data observation
  • Ports: Port 1: GH1,25 10pin | Port 2: USB type-C | Port 3: UART 2 (GH1,25 6pin)
  • Cable length: GH 10P: 150mm | GH 10P: 400mm | GH 10P to 6P: 300mm
  • Antenna Connection type: Board: SMA female | Antenna: SMA male
  • Baud rate (adjustable): 230400 5Hz default
  • Working voltage: 4,75V ~ 5,25V
  • Current Consumption: ~350mA
  • Dimension: Board: 34,8 x 58,9 x 14,4 mm | Antenna: 27,5mm (Diameter), 59mm (height)
  • Weight: 37,9g (without antennas)
  • 1x H-RTK UM982
  • 2x High Precision Helical Antennas
  • 2x Antenna Mounts
  • 2x SMA Cables
  • 2x 10pin - 10pin JST-GH Cables
  • 1x 10pin - 6pin JST-GH Cable
  • 1x 6pin - 6pin JST-GH Cable
Shipping weight: 0,30 kg
Item weight: 0,04 kg
€ 399,99
Docs MYBOTSHOP documentation
