Seeed Circuit Protection and Emergency Stop Switch Module
- SKU: MBS-Z-460
- Category: Accessories
- Manufacturers:
- Protection module with emergency stop for reBot Arm B601-RS / B601-DM
- Absorbs the regenerative energy of the joint motors
- Prevents overvoltage errors and shutdowns
The Seeed Studio Circuit Protection and Emergency Stop Switch Module for the reBot Arm B601-RS is the matching safety and braking module for the reBot Arm B601-RS robotic arm. It absorbs the regenerative energy generated by the joint motors during rapid braking and under heavy load.
Without such a module, this energy can cause the arm's supply voltage to rise. The result is an excessive bus voltage error and the robotic arm shutting down. The module reliably prevents this, ensuring stable, uninterrupted operation – even during dynamic movements and with heavy loads. It is also equipped with an emergency stop switch.
Ideal for:
- Operating the reBot Arm B601-RS at high speeds and loads
- Fast, dynamic motion sequences with frequent braking
- Research, education and data collection for imitation learning with the reBot Arm
- Setups in which the arm must be stoppable at any time via emergency stop
Key Benefits
- Prevents overvoltage errors and unwanted shutdowns
- Integrated emergency stop switch
- Specifically designed for the reBot Arm B601-RS
- Original Seeed Studio accessory
The ideal addition for anyone who wants to run their reBot Arm B601-RS safely and stably at its performance limit.
| General | |
| Compatibility | reBot Arm B601-RS |
| Function | Absorption of the regenerative (braking) energy of the joint motors, overvoltage protection for the supply bus |
| Emergency stop | Integrated emergency stop switch |
| Manufacturer part number | 100091373 |
| Connectors | |
| Power supply | 48 V, XT30 |
| Robotic arm | XT30 (2+2) |
| Communication | CAN (CANH, CANL, GND) |
| Braking resistor | R+ / R- connection |
| Terminals | Ferrule terminals, wire opening Ø 1.9 mm |
Scope of Delivery
- 1× Circuit protection and emergency stop switch module for reBot Arm B601-RS
The robotic arm is not included.
The Seeed Studio Circuit Protection and Emergency Stop Switch Module for the reBot Arm B601-DM is the matching safety and braking module for the reBot Arm B601-DM robotic arm. It absorbs the regenerative energy generated by the joint motors during rapid braking and under heavy load.
Ideal for:
- Operating the reBot Arm B601-DM at high speeds and loads
Key Benefits
- Specifically designed for the reBot Arm B601-DM
The ideal addition for anyone who wants to run their reBot Arm B601-DM safely and stably at its performance limit.
| General | |
| Compatibility | reBot Arm B601-DM |
| Manufacturer part number | 100050746 |
Scope of Delivery
- 1× Circuit protection and emergency stop switch module for reBot Arm B601-DM
