Sonair ADAR One PL d (EN ISO 13849)
  • Field of view: 180° × 180°
  • Range: up to 4 m
  • Response time: from 112 ms
  • Safety zones: 1 protection zone + 2 warning zones
  • Protection rating: IP64
Sonair ADAR One – safety-certified 3D ultrasonic sensor
According to the manufacturer, the ADAR One is the world’s first safety-certified 3D ultrasonic sensor for human-robot collaboration. Instead of scanning a single plane like a conventional safety laser scanner, it monitors a complete volume of 180° × 180° at ranges up to 4 m – including everything above, below and in between the conventional scan plane.
It is based on PMUTs, piezoelectric ultrasonic transducers in MEMS technology, combined with digital beamforming on a quad-core ARM SoC. Because the sensor works with sound instead of light, it also functions in darkness, dust and backlight and detects glass as well as reflective and low-contrast surfaces where optical sensors fail. There are no moving parts: the ultrasonic array is fixed.
Your advantages at a glance
  • Certified safety: SIL 2 to IEC 61508 and PL d to EN ISO 13849, EC type-examination certificate from exida
  • Volume instead of plane: the 180° × 180° field of view also captures low and overhanging obstacles
  • Independent of light: reliable in darkness, dust and backlight as well as on glass and reflective surfaces
  • 128 zone presets: three simultaneously monitored zones per preset, switchable via eleven safe inputs
  • Compact and efficient: 104 × 54 × 25 mm, 200 g, maximum 5 W
  • Several sensors side by side: no crosstalk where detection ranges overlap
  • ROS 2-ready: 3D point cloud over Ethernet in addition to the safe OSSD output
Field of view 180° × 180°
Detection range 0–4 m; 0–5 cm obstacle detected, position not reported
Range precision 2–10 cm
Angular precision 0–45°: approx. 3° · 45–70°: approx. 6° · 70–90°: over 10°
Detection capability (safety function) Torso (≥ Ø155 mm): 0–3 m at 0–75°, 0–2 m at 0–80°
Legs (≥ Ø70 mm): 0–2.5 m at 0–60°, 0–1.5 m at 0–80°
Cylinder, acoustically hard (≥ Ø30 mm): 0–3 m at 0–60°, 0–1.5 m at 0–80°
Response time min. 112 ms
Frame rate max. 18 Hz
Ultrasonic frequency 65–85 kHz
Zones 3 simultaneously (1 protective zone, 2 warning zones) per preset, 128 presets
Safe outputs 1× OSSD pair (protective zone), 2× status output (inner and outer warning zone)
Safe inputs 11 static control inputs for zone selection
Data interface Ethernet (CoAP over UDP/IP) for 3D point cloud and configuration
Indicators 2 dual-colour LEDs for OSSD and system status
Power supply 24 V DC (18–28 V, SELV/PELV), max. 5 W
Dimensions / weight 104 × 54 × 25 mm (W × H × D), 200 g
Ingress protection IP64
Operating temperature 0 to +50 °C
Safety parameters SIL 2 (IEC 61508), PL d (EN ISO 13849), PFH below 1.5 × 10⁻⁷/h; assessed to IEC 61496 with adaptations for ultrasound
Typical applications
  • Autonomous mobile robots in warehousing, production, logistics, retail and hospitals
  • Machine safety at robot cells, palletisers, CNC machine tending and packaging lines
  • Redundant safety layer alongside LiDAR and cameras – sound instead of light closes perception gaps
  • Adding vertical awareness and close-range detection
  • Compact robot platforms with limited space and energy budget
  • 1× Sonair ADAR One
Price on request
  • Available immediately
