Stereolabs Camera Mount für ZED X One S
- SKU: MBS-Z1-291
- Category: Accessories
Manufacturers:
Stereolabs Camera Mount for ZED X One S
- Original Stereolabs mount for the ZED X One S
- Sturdy and precise, made from aluminium
- Three versions: tripod, front or floor mounting
The Stereolabs Camera Mounts for the ZED X One S are rugged mounts made of high-quality aluminum that let you attach the camera securely and precisely aligned to robots, workcells, forklifts or fixed installations. They ensure stable alignment and reliable hold, even in continuous operation.
The mount is available in three versions: The Plate is an adapter plate with a standard 1/4"-20 UNC tripod thread for common tripods and accessories. The Front mount attaches the camera to the front structure or frame of a robot, while the Bottom mount attaches it to a structure underneath. Slotted holes allow flexible positioning or continuous angle adjustment.
Ideal for:
- Mobile robots, AMRs and autonomous forklifts
- Robotic workcells and industrial automation
- Fixed monitoring and measurement stations
- Prototypes and test setups with a tripod
Key Benefits
- Original Stereolabs accessory for the ZED X One S
- Rugged and precise, made of high-quality aluminum
- Three versions for tripod, front or bottom mounting
- Plate with standard 1/4"-20 UNC tripod thread
- Front and Bottom with slotted holes for flexible alignment
- Screw kit included
The ideal choice for anyone who wants to mount their ZED X One S securely, stably and precisely aligned.
Versions Compared
| Version | Plate | Front | Bottom |
| Mounting | Tripod and accessories | Front structure / frame | Structure underneath |
| Fastening | 1/4"-20 UNC thread (bottom) | 2 slots 20 mm, Ø 5.4 mm | 2 curved slots 20 mm, Ø 5.4 mm |
| Adjustment | via the tripod | Position adjustable | Angle adjustable |
| Dimensions | 22 × 20 × 6.2 mm | 27.22 × 55 × 4 mm | 30 × 50 × 4 mm |
| Manufacturer part no. | ACC-151200 | ACC-151300 | ACC-151400 |
| General | |
| Compatibility | Stereolabs ZED X One S |
| Material | Aluminum |
| Versions | Plate, Front, Bottom |
| Country of origin | France |
Scope of Delivery
- 1× Camera mount in the selected version (Plate, Front or Bottom)
- 1× Screw kit
Note: The camera is not included in the scope of delivery.
