Stereolabs GMSL2 Capture Card Duo
  • SKU: MBS-Z-308
  • GTIN: 0658917599836
  • HAN: ACC-210000
  • Category: Accesoires
  • for four ZED X cameras in all Jetson Orin and Xavier models
  • up to 40Gb/s total bandwidth
This premium GMSL2 capture card allows you to capture up to four ZED X cameras on all Jetson Orin and Xavier models.
With its impressive performance, it opens up completely new possibilities in image processing.
Compatibility with carrier boards
Use the Stereolabs GMSL2 Capture Card Quad with NVIDIA Jetson AGX Orin, AGX Xavier, and carrier boards to fully leverage the performance of this premium imaging solution.
Discover new dimensions of image processing and take your projects to a higher level with the Stereolabs GMSL2 Capture Card Quad!
Technical Data
  • High-performance quad capture card for Jetson.
  • Capture 4x GMSL2 cameras in SD/HD/4K with up to 4K@30.
  • Up to 40Gb/s total bandwidth.
  • Hardware synchronization for multiple cameras at shutter level.
  • Support for external trigger/flash hardware synchronization.
  • Requires external power supply of 12-19V.
  • Connects to Jetson Orin/Xavier AGX SAMTEC CSI port.
  • Includes two 0.3m (0.98ft) 1-to-4 GMSL2 cables.
Camera Inputs
  • Supports 4x ZED X stereo cameras.
  • Supports 4x ZED X One cameras.
  • Supports 4x ZED X + 4x ZED X One cameras.
  • 1x GMSL2 capture card
  • 2x 1-to-4 GMSL2 cables 0.3m
  • 1x JST to jack plug
  • 1x 12V power supply
€ 451,99
Others also bought:
Docs MYBOTSHOP documentation
