TBS 500 Quadcopter Frame
  • SKU: MBS-DR-22
  • Category: Drones
  • three versions: Fiberglass, PCB and Carbon Fiber
  • 4x 450 arm
  • compatible with 3S 5000mAh-6000mAh battery or 4S 2500mAh-3700mAh battery
TBS Quadcopter frames are made of durable materials for better resistance to damage or harder landings. These frames come in three versions: Fiberglass, PCB, and Carbon Fiber. They are special constructions for GoPro FPV multicopter and suitable for DIY of your own quadcopter.
  • PCB frame with solder points and a reserved space for flight control
  • Capable of loading a GoPro and a camera when they are smaller than 32x32mm.
  • Mounting holes are available in the middle of the plate
  • Supports most X mode flight control boards.
  • Arm: 4x 450 arm, high strength screws
  • Compatible with: 3S 500mAh-600mAh battery or 4S 2500mAh-3700mAh battery
  • 1x TBS 500 Quadcopter Frame
from
€ 34,95
  • Available immediately
Docs MYBOTSHOP documentation
