UAV RFD 868x-EU Long Range Modem
  • SKU: MBS-Z-113
  • GTIN: 0096718606016
  • HAN: MODEM-RFD868x-EU
  • Category: Accesoires
UAV RFD 868x-EU Modem
  • > 20 km Range
  • 0,5W Transmission power
  • small Dimensions
  • easy Implementation
Please note that without the appropriate radio operator license, the transmission power must be throttled to 25mW.
The UAV RFD 868x is a modern telemetry modem used for data transmission with a transmission power of 0,5W, allowing a maximum range of up to 20km.
The implemented firmware is an Open Source development enviroment called "SIK". The firmware is based on a 32bit ARM Prozessor and can be configurated via an FTDI converter.
  • Frequency Spectrum: 868-869 MHz
  • Transmission power: 0,5W
  • Transmission rate: 2 - 200 kbit/sec.
  • UART transmission rate: 9600 - 921k baud
  • Reciever sensivity : > 121 dBm
  • Dimensions: 30 x 57 x 12,8mm
  • Weight: 14,5g
  • Working voltage: 5V @ 800mA
  • Working temperature: - 40 to 80°C
Interfaces
  • RF: 2 x RP-SMA
  • Serial TTL (3,3V)
  • 1 x RFD868x-EU Modem
Shipping weight: 0,02 kg
Item weight: 0,02 kg
RFD868 CE / EU Declaration
€ 171,95
