Yarbo lawn mower (Body+M1 Pro)
- SKU: MBS-YAR-13
- GTIN: 0658917504724
- HAN: C010020015/C010030005
- Category: Robots
- Manufacturers:
Yarbo Lawn Mower (Body+M1 Pro)
- Autonomous, modular lawn mower
- Smart navigation for precise mowing
- App control for easy operation
- Suitable for various lawn types
- Powerful and reliable performance
The Yarbo Lawn Mower (Body+M1 Pro) is an innovative, high-performance lawn care solution designed for precise and effortless grass cutting. Equipped with the powerful M1 motor and an intelligent design, it delivers exceptional mowing results even on uneven terrain or dense grass areas. Whether trimming large lawns or navigating around obstacles, this mower ensures a smooth and uniform cut, promoting a healthier and greener lawn.
Featuring an advanced lithium-ion battery system, the Yarbo Lawn Mower provides extended runtime, allowing you to mow even large areas without interruptions. The fast-charging capability ensures that the battery is quickly recharged and ready for the next use. Its user-friendly controls and ergonomic handle design offer a comfortable mowing experience, reducing strain even during prolonged use.
With a cutting width of 40 cm, this mower efficiently covers large lawn surfaces, reducing the time needed to complete the job. The adjustable cutting height, ranging from 30 mm to 80 mm, provides flexibility to match different lawn conditions and preferences. Precision rotary blades ensure a clean, even cut, which helps prevent lawn diseases and promotes healthier grass growth.
One of its standout features is the combination of a lightweight yet durable frame, weighing only 12 kg. This makes it easy to transport and store while maintaining stability and longevity. Maintenance is hassle-free, as key components are easily accessible for cleaning and servicing. For added safety, the mower is equipped with an overload protection system, automatic shutoff, and a protective blade cover to ensure secure operation.
Technical Specifications
- Model Name: Yarbo Lawn Mower (Body+M1 Pro)
- Motor: High-performance M1 motor for precise and efficient mowing
- Battery: Long-lasting lithium-ion battery with fast charging
- Runtime: Depends on terrain and usage
- Cutting Width: 50 cm for fast and efficient lawn coverage
- Adjustable Cutting Height: 2-10 cm for optimal customization
- Weight: ca. 42 kg – lightweight yet robust
- Maximum Lawn Area: Up to 600 m²
- Technology: Precision rotary blades for a clean, professional cut
- Safety Features: Overload protection, automatic shutdown, protective blade cover
- Noise Level: Low-noise operation for a pleasant mowing experience
Scope of Delivery
- Yarbo Lawn Mower (Body) with high-performance M1 Pro motor
- Premium lithium-ion battery
- Fast-charging power adapter
- Comprehensive user manual for easy operation
- Protective blade cover
- Maintenance tools for long-lasting performance
| Item information | Value |
| Shipping weight: | 60,00 kg |
| Item weight: | 42,00 kg |
