Yarbo M1 Pro Lawn Mower Module
  • SKU: MBS-YAR-12
  • GTIN: 0658917504717
  • HAN: C010030005
  • Category: Robots
  • Modular lawn mower system for precise mowing
  • Automated navigation without boundary wire
  • Powerful battery for large lawns
  • Weather-resistant and suitable for all seasons
  • Easy control via app and smart home integration
The YARBO M1 Pro Mowing Module is the powerful extension of the modular YARBO system. It transforms the versatile yard robot into a fully automatic lawn mower – ideal for large areas and demanding conditions. Whether uneven terrain, slopes, or thick, damp grass – the M1 Pro module easily handles tasks where conventional robotic mowers often reach their limits.
Powerful, Precise, and Flexible
With the M1 Pro, you benefit from a wide cutting mechanism (approx. 50 cm / 20 in) that efficiently covers large areas. The adjustable cutting height from about 2 to 10 cm (0.8–4 in) allows precise customization – from a perfectly manicured lawn to tougher grass surfaces.
Thanks to its excellent terrain capability, the robot easily handles slopes up to around 35° (≈70%). Advanced navigation technology using RTK-GPS, vision sensors, IMU, and odometry enables accurate guidance – completely without boundary wires. Obstacles are safely detected and avoided.
The modular concept provides maximum flexibility: the mowing module can easily be attached to the main unit (“Core”) or replaced with other modules – for example, for snow removal or leaf blowing. Convenient functions such as automatic charging, return to base station, and integrated rain and obstacle detection make operation even easier.
Technical Data (Excerpt)
Specification Details
Cutting width approx. 50 cm (20 in)
Adjustable cutting height approx. 2 – 10 cm (0.8 – 4 in)
Maximum lawn area up to 25,000 m² (≈6 acres)
Slope capability up to approx. 35° (≈70%)
Motor power two motors, each approx. 300 W
Module weight approx. 30 – 32 kg
Noise level approx. 60 dB
Water protection / IP rating IPX6
Dimensions (L × W × H) approx. 69 × 74 × 40 cm
Scope of Delivery
  • YARBO M1 Pro mowing module
  • Charging station with power adapter
  • Installation accessories (e.g. mounting parts and connection cables)
  • User manual in English and German
  • Maintenance and cleaning kit
Shipping weight: 60,00 kg
Item weight: 40,50 kg
Others (2)
Mower User Manual
Mower QuickStartGuide
€ 2.689,95
