iSDT X16 Dual Channel AC/DC Smart Charger - 1100W 20A 10-72V
  • SKU: MBS-ISDT-01
  • GTIN: 0096718607594
  • HAN: X16
  • Category: Charging
  • 1100W 20A 10-72V
  • max. charging power: 1100W
  • max. Input: 20A
  • Output voltage DC: 10-72V
The X16 from iSDT is a professional dual Chanel 16S smart charger. It supports 2~16S LiFe, LiPo, LiHv and ULiHv batteries. Ultra high power lithium battery with 4.45V is no problem. The maximum total output power of the charger is 2200W (at 220V AC). The high energy output takes place continuously.
The X16 uses an 18pin balance port, and both channels can independently support 2~16S lithium batteries.
Supported the AC 120V and AC 220V voltage input by an independent dual 1100W x2 (@220V AC) high power AC power supply, with short circuit, overload, under voltage, over voltage and over temperature protection.
The two independent and stable channels, work independently or can be combined. Only a constant current flow is required for X16 stability. The device features synchronous parallel charging, with a maximum power of up to 1800W at 220V AC. The charging current range of the X16 is 21~35A.
Bluetooth connection
The charger can be connected to the cell phone via Bluetooth. So you can also control the device to perform tasks or view the detailed parameters of the channels in the app "ISD Link". Charging tasks can also be preset in the app and one-touch charging, instead of lengthy charging steps, can be used. The OTA upgrade is imminent here.
Display
This is an IPS screen with automatic brightness adjustment and low power consumption. The display has a viewing angle of 178° and is clearly visible, even in strong sunlight or at different angles.
  • Supports 2-16S LiFe, LiPo, LiHv, ULiHv, and ultra-high voltage lithium batteries
  • Independent dual AC channels
  • Multiple Operation Modes
  • Two-way USB interface
  • 2.8'' IPS LCD screen
  • Dual Fast ChargingParallel Charging
  • Input voltage AC 100~240V
  • Output voltage DC 10-72V
  • Max. input current 20A
  • Charging current 1~20A
  • Discharging current 0.5~3.0A
  • Max. charging power 1100W*2
  • Max. discharging power 50W*2
  • Balance current 1.5A/Cell
  • working temperature: 0°C-40°C
  • Dimension: 276 x 246 x 82 mm
  • 1 x iSDT X16
Shipping weight: 4,00 kg
Item weight: 3,50 kg
iSDT x16 Manual
€ 915,00
Docs MYBOTSHOP documentation
