AVerMedia D331ATB Box PC
  • SKU: MBS-AVM-29
  • GTIN: 05390368407197
  • HAN: D331ATB
  • Category: Electronics
  • Compatible with Jetson T5000™ / T4000™
  • CE, FCC, VCCI, KC (TBD)
The AVerMedia D331ATB is a high-performance BOX PC optimized for the NVIDIA Jetson T5000™/T4000™ modules. This efficient system-on-module platform unlocks new possibilities for embedded IoT applications, offering comprehensive analytics capabilities and seamless AI integration.
Specifically designed for industrial applications with limited space, the D331ATB provides a wide range of I/O ports, enabling rapid development of AI-based solutions and smooth implementation. AVerMedia supports businesses of all sizes through flexible BSP services, customizable minimum order quantities, and compatibility with the NVIDIA JetPack™ SDK.
Key Industries
AVerMedia devices are designed for flexibility and are particularly suitable for:
  • Autonomous Mobile Robots (AMRs) – Utilize live camera images to dynamically adjust workflows and boost productivity.
  • Smart Security – Real-time video data enables analysis to enhance safety and surveillance.
  • Smart Inspection – Rapid and precise visual inspections improve quality control and efficiency in production.
Technical Data
Model D331ATB
Type BOX PC
NVIDIA Module Compatibility Jetson T5000™ / T4000™
Network 2× GbE RJ-45 (OOB onboard, one port NCSI)
1× QSFP for 4×25GbE
1× M.2 Key E 2230 for WiFi 6
1× M.2 Key B for 5G
Display Output 1× HDMI 3840×2160 @ 60Hz
1× USB-C (DisplayPort mode)
2× HDMI optional
Temperature Range Operating: -25°C to 50°C
Storage: -40°C to 85°C
Relative humidity: 40°C @ 95%, non-condensing
Camera Inputs 1× 120-Pin GMSL camera board
USB Ports 1× USB 3.2 Type-C (BSP installation)
2× USB 3.1 Type-C
4× USB 3.2 Type-A
Optional 8× USB 3.2 Type-A via expansion board
SIM Slots 2× SIM for 4G/5G dual-SIM support
Storage 2× NVMe M.2 Key M 2280
Optional PCIe Gen5 configurations
TPM TI SLB9672XU2.0
Expansion Ports Multiple COM, DI/DO, UART/RS232/RS485/RS422, CAN-FD, JTAG, PCIe expansion slots, GPIO, I2C, etc.
GPS mPCIe slot for optional dual-RTK GNSS (via expansion board)
Sensors Temperature measurement for top/bottom PCB
Power Supply 9–36V DC via 3-pin terminal block & Mini-Fit 6-pin
ACC IN / IGN control optional
Cooling 1× SoM fan
2× chassis fans (12V)
Buttons Power, Recovery
LED Indicators System Power, Input Power
Miscellaneous Mini-Fit 4-pin DC output for PSE expansion, DC output for GMSL, USB-C debug UART, DIP switch functions, AT/ATX mode selection, ACC on/off
RTC Battery Supports RTC battery with MCU-based monitoring
Mechanical Data Width: 10 mm × Length: 170 mm (TBD), Weight: 250 g (TBD)
Certifications CE, FCC, VCCI, KC (TBD)
  • 1× D331ATB Box PC
  • Screws
Shipping weight: 0,50 kg
Item weight: 0,25 kg
€ 10.714,95
