AVermedia Edge PC D315AOP
AVermedia Edge PC
  • Versions: 32GB and 64GB
  • with Fanless Chassis
  • NVIDIA® Jetson AGX Orin & AGX Orin Industrial module
The AVerMedia AI Box PC D315AOP 5G is equipped with the NVIDIA® Jetson AGX Orin™ module, offering next-generation AI performance and energy-efficient features for autonomous machines. This powerful System-on-Module (SoM) enables advanced analytics and supports a wide range of other embedded IoT applications.
The D315AOP 5G features a 120-pin high-speed connector specifically designed for connecting MIPI-SerDes cameras, meeting the needs of autonomous mobile robots (AMRs) (note that the adapter board and MIPI camera are not included). With a 10G Ethernet bandwidth, the system is excellent for smart security applications, enabling the simultaneous transmission of dozens of IP cameras. The 10GigE Vision camera port is also ideal for intelligent inspection tasks. Despite its compact design, the D315AOP 5G offers a PCIe slot for multifunctional expansions and excellent compatibility with Wi-Fi 6 and 5G.
AVerMedia devices are designed with flexibility in mind and are tailored for the following vertical markets:
  • Autonomous Mobile Robots (AMRs): AMRs use live camera feeds to quickly and flexibly adapt work processes, leading to significant productivity gains.
  • Smart Security: By utilizing live camera streams and video analysis, community safety is enhanced and ensured.
  • Intelligent Inspection: Live camera feeds enable fast and precise detection, optimizing quality control in production.
  • NVIDIA Jetson SoM: NVIDIA® Jetson AGX Orin (32G/64G) & AGX Orin Industrial
  • Networking: 1x GbE RJ-45, 1x 10G RJ-45
  • Display Output: 1x HDMI 2.0 (3840x2160 at 60Hz)
  • Operating temperature D315AOP 32G: -25°C~50°C
  • Operating temperature D315AOP 64G: -25°C~40°C
  • Storage temperature: -40°C ~ 85°C
  • Relative humidity: 40 °C @ 95%, Non-Condensing
  • 1x USB 2.0 Micro-B for recovery
  • 2x USB 2.0 Type-A
  • 2x USB 3.2 Type-A
  • Audio: Intel HD Audio analog connector
  • Storage: 1x micro-SD card Slot
  • Expansion Header
    • 40-pin (UART, SPI, CAN, I2C, I2S, GPIOs)
    • 1x M.2 B key (for 4G LTE module or 5G module)
    • 1x M.2 E key (for Wi-Fi 6E)
    • 1x M.2 M key (for SSD or AVerMedia capture card:CN311-H, CN312SW, CN312MW)、1x Micro SIM socket
    • 1x PCIe x16 (only support x8 PCIe lanes)
    • 1x CAN bus with transceiver, 120-pin (for MIPI SerDes*) *The adaptor board is not included but can be customized by project. Please contact our sales for more infomation.
  • DC in jack on board:  54V/2.78A adapter
  • DC Range: 12~54V (7~1.95A)
  • ATX 4-pin: 12~54V (10.8~2.4A)
  • Thermal Solution: Fanless solution
  • Buttons: Power and Recovery
  • Dimensions: 160mm * 136.9mm * 65mm
  • Certifications: CE, FCC, VCCI, KC
  • 1x D315AOP
  • 1x Adapter 54V/2.78A and Power cord
Shipping weight: 1,80 kg
Item weight: 1,55 kg
from
€ 3.929,95
