AVermedia Engeneering Kit D131ONB
  • SKU: MBS-AVM-26
  • GTIN: 0658917512354
  • HAN: D131ONB 4GB
  • Category: Electronics
  • 4GB
  • NVIDIA® Jetson™ Orin NX/Orin Nano Module
  • Support RTC Battery and Battery Life Monitoring by MCU
The AVerMedia Engineering Kit D131 with the NVIDIA® Jetson™ Orin NX/Orin Nano module provides an efficient System-on-Module (SoM) that enables advanced analytics and supports a variety of embedded IoT applications.
The D131 is a ready-to-use device that integrates cameras, SSD and thermal solutions. Its vertical mechanical design provides an optimized user experience. The power input and the extended 40-pin connector are located at the bottom to avoid cable clutter. The multi-camera support and compact design are particularly noteworthy.
AVerMedia devices are designed to be flexible and suitable for the following applications:
  • AMRs use live camera transmissions to quickly and flexibly adjust work processes, significantly increasing productivity.
  • Intelligent security systems benefit from live camera feeds and video analytics to improve and ensure safety in communities.
  • Intelligent inspection systems use live camera feeds for fast and accurate detection, optimizing quality control in production.
  • NVIDIA Jetson SoM: Jetson Orin NX / Orin Nano
  • Networking: 1x GbE RJ-45 (PoE option), 1xM.2. key E 2230 for Wi-Fi
  • Display Output: 1x HDMI 2.0 (3840 x 2160 at 60Hz for Orin NX/ at 30Hz for Orin Nano)
  • Operating temperature 0°C~65°C
  • Storage temperature -40°C ~ 85°C
  • Relative humidity 40 °C @ 95%, Non-Condensing
  • MIPI Camera Inputs
    • 2x 2 lane MIPI CSI-2, 15 pin FPC 1mm Pitch Connector
    • 1x 4 lane MIPI CSI-2, 36 pin FPC 0.5mm Pitch Connector
  • USB: 1x USB 2.0 Micro-B for recovery, 4x USB 3.2 Gen1 (5G) type A
  • Storage*: 1x M.2. key M 2280 for SSD
  • Expansion Header
    • 40-pin
    • 1x UART, 2x  SPI, 2x 12C, 1x I2S, 6x GPIOs
    • 1xCAN with transceiver (3-pin terminal block)
    • 1xOOB supported by Allxon
  • Input Power: DC in jack on board & ATX 4-pin, 12V/5A, 9V~24V is recommended
  • Power Cord: US/JP/EU/UK/TW/AU/CN (optional)
  • Thermal Solution: Fan
  • Buttons: Power and Recovery
  • Dimensions: 157mm(W) x 105mm(L) x 85mm(H) with stand (without antenna)
  • Weight: 415g
  • Certifications: CE, FCC, KC
  • 1 x Carrier Board
  • 1 x NVIDIA® Jetson module + Fan
  • 1 x Stand
  • 1 x 256G SSD (preinstalled)
Shipping weight: 1,00 kg
Item weight: 0,42 kg
€ 959,95
