AgileX Auto Kit Pro
AgileX Auto Kit Pro
  • Platform not included
  • GPS included
  • Compatible with HUNTER, HUNTER2.0, SCOUT2.0, and BUNKER
  • Packed in a wooden case
The AgileX Auto Kit Pro is a professional development and research kit for autonomous driving systems. It combines powerful sensors, computing hardware, and pre-installed software (ROS & Autoware) to enable functions such as autonomous navigation, SLAM, obstacle detection, and path planning. The kit can be installed on various UGV platforms such as Scout, Hunter, or Bunker, and is ideal for research, education, and industrial prototype development.
Technical Data
  • Industrial onboard computer (e.g., Intel i7) for compute-intensive autonomous applications
  • Up to 32 GB RAM
  • Multiline LiDAR (e.g., 16-channel) with a range of up to approx. 150 m
  • Stereo depth camera for visual navigation and SLAM
  • USB-to-CAN communication module
  • Power supply module for use on UGV chassis (e.g., 24 V → 12 V / 19 V)
  • LCD display for visualization and system diagnostics
  • Typical kit weight: approx. 30 kg
  • Pre-installed software: Linux, ROS, Autoware, example scenarios
Scope of Delivery
  • AgileX Auto Kit Pro main module
  • Industrial computer (IPC)
  • LiDAR sensor
  • LCD display module
  • USB-to-CAN adapter
  • Power supply module / power converter
  • Mounting plates and brackets
  • Cable set
  • Documentation and software packages
  • Durable transport or wooden case
Shipping weight: 120,00 kg
€ 38.080,00
