Airbot Systems Mini Power Brick
  • Compact and suitable for any type of UAV.
  • Supports up to 12S voltage and 3A continuous power.
  • Integrated voltage and current sensing for monitoring energy consumption.
Airbot Systems Mini Power Bricks encapsulate a high-quality switch voltage regulator, that can support up to 12S voltage and 3A continuous power output. It has been developed to be as compact as possible and can be installed in any kind of UAV.
The Mini Power Brick integrates built-in voltage and current sensing. The voltage & current information is used to determine the consumed power and to estimate the remaining battery capacity. This, in turn, allows the flight controller to provide failsafe warnings and other actions in the event of low power.
Spezifikationen:
  • Diam mounting holes: M3
  • Mounting holes distance: 38mm
  • Weight: 31g
  • Max input voltage: 12S
  • Max current output: 3A
  • Max peak current: 4A (
  • Voltage probe: Up to 12S
  • Max current measurement: 100A
Lieferumfang:
  • 1* Airbot Systems Mini Power Brick
  • 1* Cable
Item weight: 0,03 kg
€ 124,95
