Airbot Systems Power Supply
  • SKU: MBS-ISDT-22
  • GTIN: 0658917512323
  • HAN: ASX-009
  • Category: Charging
  • Provides a clean, stabilized voltage from source up to 12S
  • Selectable output options: 5V0, 5V3, or 12V at 3A max
  • Can be soldered to a motherboard or used wired
The Airbot Systems switching power supply is a high quality electronic component that provides up to 3A continuously and can withstand momentary spikes of up to 4A. With an input voltage capable of supporting up to 50.4V (12S), it is capable of providing an output voltage of 5V, 5.3V or 12V, user selectable depending on application needs.
Specifications:
  • Input Voltage: Supports up to 50.4V (12S)
  • Continuous Output: Up to 3A, momentary spikes up to 4A
  • User Selectable Voltage: 5V, 5.3V or 12V
  • Mounting Options: Solderable to a motherboard or wired using included PCB
  • Dimensions: 24x23x6.15mm / 0.94x0.90x0.24in (without cable)
Package Includes:
  • 1x 3in1 Power Module
  • 1x PCB for Wired Mounting
  • 1x 6cm Cable (Molex ClickMate 6P 1.25mm to Molex ClickMate 6P 2.00mm)
€ 67,95
