ArduCAM NVIDIA Jetson Cam 1MP OV9281 GS 130deg M12
- SKU: MBS-SES-192-08
- GTIN: 0618455045813
- HAN: B0223
- Category: Sensors
Manufacturers:
ArduCAM NVIDIA Jetson Cameras
- ArduCam cameras for the NVIDIA Jetson Developer Kits
- 8MP IMX219 cameras with various attachments
- 1MP OV9281 Global Shutter 130deg M12
These cameras were specially developed for use with the NVIDIA Jetson Developer Kit.
The 8MP IMX219 cameras with various attachments are used here to cover as many requirement areas as possible in terms of autofocus, wide angle, low distortion, etc. with the cameras.
The ArduCAM NVIDIA Jetson Camera 1MP OV9281 Global Shutter 130deg M12 module falls within the scope of the Jetvariety project. This module allows any camera module to be connected to the high-speed CSI-2 connector on the Jetson Nano.
The ArduCam team released the OV9281 Global Shutter Monochrome (B&W) MIPI camera module with a resolution of 1280 x 800, developed based on the 1/4" Omnivision OV9281 image sensor, which uses OmniPixel3-GS technology. This allows it to deliver full frame, sub-sampling and windowed 8/10 -bit MIPI images. It is also capable of operating at up to 120 frames per second at full resolution on the 1-lane MIPI bus. At the same time, the user has complete control over the quality of the image.
The camera driver is kernel dependent. If an upgrade or downgrade is made, this must also be done with the opposite side.
Applications for this module include: security, high dynamic range imaging, stereo vision, unattended surveillance, automation, and machine vision.
- Sensor: monochrome global shutter OV9281
- Pixel size: 3 μm x 3 μm
- Active area size: 1280 x 800
- Optical size: 1/4"
- Focus range: 30mm to infinity
- Output interface: 2-lane MIPI serial output
- Output formats: 8/10-bit BW RAW
- image transfer rate: max. 1280 x 800@120fps
- card size: 40 x 40 mm
- IR: no integral IR filter, sensitive to IR
- FoV: 130°(D), 110°(H), 90°(V)
Driver:
- Supports Gray, Y10, Y16
- Supports standard V4L2 framework, video nodes and controls (exposure, gain and camera dependent parameters)
- OpenCV friendly
- Provides source code demonstration
- One-line driver installation command
- Supports externally suitable global shutter camera
- Supports synchronization of two cameras
Scope of delivery:
- 1 x ArduCAM NVIDIA Jetson Camera 1MP OV9281 Global Shutter 130deg M12
