ArduCAM USB Camera Module IMX296 Color GS 1.58MP
  • SKU: MBS-SES-260
  • GTIN: 0658917510862
  • HAN: B0499
  • Category: Sensors
  • Plug and Play
  • Based on 1.58MP IMX296, maximum resolution of 1456*1088
  • Proprietary, integrated ISP
  • Color global shutter at 90 frames per second -High-speed USB3 connectivity
  • 6mm CS-Objectiv
Arducam's USB 3.0 camera series offers the IMX296 color global shutter model. This camera is equipped with a 1.58MP CMOS sensor and provides a maximum still resolution of 1456×1088, producing uncompressed, high-quality images in YUYV format.
The integrated ISP optimizes image quality, while the global shutter, USB 3.0 connectivity, and a fast frame rate of 44fps enable seamless video recording. Equipped with a 6mm CS lens with a 60° diagonal field of view, the camera delivers precise and detailed images for a variety of applications.
Arducam's latest USB 3.0 camera stands out with its user-friendly plug-and-play functionality. It is compatible with Windows and Linux operating systems, requiring no additional drivers, simplifying the setup process. Additionally, it offers backward compatibility with USB 2.0 host ports for flexibility and seamless connectivity.
Applications
  • Machine Vision
  • Video Surveillance
  • 3D Scanning and Metrology
  • Live Streaming
  • Video Conferencing
  • Outstanding Imaging: Arducam's IMX296 USB3 camera features a 1.58MP color global shutter sensor, providing exceptional clarity with a resolution of 1456×1088.
  • High-Speed USB 3.0 Connectivity: Enjoy flexible frame rates up to 44fps and global shutter functionality, ensuring artifact-free high-speed motion capture.
  • 6mm CS Lens: The camera is equipped with a 6mm CS lens that allows manual adjustments for sharp, clear images tailored to your needs.
  • Advanced Image Enhancement: The integrated ISP uses proprietary technology to ensure top-tier image quality through de-Bayering, gamma, BLC, AE, AWB, CCM, and RGB2YUV processes.
  • Plug and Play: Seamless compatibility with Windows and Linux operating systems and plug-and-play functionality eliminate the need for additional drivers.
  • Sensor: IMX296
  • Still Resolution: 1.58 MP
  • Color Filter Type: Color
  • Shutter Type: Global Shutter
  • Optical Size: 1/2.9″
  • Output Format: YUY2
  • Pixel Size: 3.45μm × 3.45μm
  • Sensor Active Area: 1456(H) × 1088(V)
  • Frame Rate (USB 3.0): 1456×1088@44fps
  • Frame Rate (USB 2.0): 1456×1088@10fps
  • Focus Type: Manual Focus
  • FOV: 60°(D)×50°(H)×38°(V)
  • Lens Mount: CS Mount
  • F.NO: F1.2
  • E.F.L.: 6mm
  • IR Sensitivity: Integral IR-cut filter, visible light only
  • Default Focus Range: 3m to infinity
  • Interface: USB 3.2 Gen 1 device, backward compatible with USB 2.0 hosts
  • Connector: Type-C reversible interface connector
  • UVC Compliant: No additional drivers required
  • Operating Voltage: 5 V +/- 5%
  • Operating Temperature: 32°F-158°F (0°C to 70°C)
  • Power Requirements: Max: 1.89W, Min: 1.62W
  • Camera Board Size: 34mm x 34mm
  • Supported OS: Windows, Linux
  • Recommended Sample Application: PotPlayer for Windows, qv4l2 for Linux
  • UVC Controls: Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Exposure (Manual/Auto)
  • 1 x IMX296 USB3 Camera with Backboard and Tripod Adapter
  • 1 x 1m USB A to Type-C Cable
Notes
  • The tripod is not included in the package. Please check UB0224 and UB0216 for additional purchase.
€ 239,95
