ArduCam 12MP USB-Kameramodul mit M12-Objektiv, 1/2,3'' 3840(H)×3032(V) 4K@30fps
```html
ArduCam 12MP USB Camera Module with M12 Lens, 1/2.3'' 3840(H)×3032(V) 4K@30fps
  • 64 Megapixels
  • 10x Digital Zoom
  • Smooth Upgrade
Arducam UVC Camera
Overview:
This camera is a NEW UVC camera from Arducam. This camera is based on a high-resolution 12 MP image sensor. The maximum resolution and frame rate are 4056 (H) × 3040 (V) at 30 frames per second. Additionally, we have equipped the camera with a wide-angle M12 lens with manual focusing. The Arducam team strives to develop more comfortable and efficient camera solutions. We have expanded the application range of the image sensor so that the camera can realize your various projects. It is equipped with a 110°(H) wide-angle M12 lens. Wide-angle lenses allow for more foreground inclusion, and greater depth of field improves the overall composition and coherence of the subject in the shot. It is compatible with Windows, Linux, Android, and MAC, and no additional drivers are required. If you have further requirements, please contact our sales team. We look forward to further collaboration with you.
Applications:
  • 3D Scanner
  • VR Camera
  • Lightburn Laser Engraving Machine
  • Surveillance
  • Video Systems
Features:
  • 4K HD High Resolution: Based on a 12 MP CMOS image sensor with M12 lens; Maximum resolution: 3840 (H) × 3032 (V). 4K Ultra HD allows capturing the most exciting details at 4K at 30 frames per second. Compression format: MJPG / YUY2
  • Wide-Angle M12 Lens: Equipped with a 110° (HFOV) wide-angle M12 lens. Wide-angle lenses allow for more foreground inclusion, and greater depth of field improves the overall composition and coherence of the subject in the shot. Additionally, you can swap out other lenses compatible with the M12 lens mount (Note: Lens optical size must match the sensor optical size).
  • UVC Compatible: OTG Support: Simply plug the USB cable into your PC's USB port, and with the software, you can record high-level videos and continuous recordings without the need for a driver.
  • Wide Compatibility: USB cameras are widely used for Raspberry Pi, Windows, Android, Linux, and Mac OS with UVC protocol.
  • Additional Applications: Perfect for embedded applications, video systems, 3D scanners, VR cameras, electronic microscopes, and medical devices
Camera Specifications
Property Details
Resolution 12 MP
Color Filter Type Color
Shutter Type Rolling Shutter
Optical Size 1/2.3"
Output Format YUYV/MJPG
Pixel Size 1.55um x 1.55um
Active Sensor Area 3840 (H) × 3032 (V)
Frame Rate MJPG: 3840*3032@30fps/640*480@30fps/1920*1080@30fps/1280*720@30fps/4160*3120@30fps/3840*2880@30fps/3840*2160@30fps
YUYV: 3840*3032@1fps/640*480@30fps/1920*1080@5fps/1280*720@10fps/41603120@1fps/3840*2880@1fps/3840*2160@1fps
Focus Type Manual Focus
Field of View 110°(H)
Lens Mount M12*P0.5
F.NR 2.8 ± 5%
EFL 14.5 ± 0.2 mm
Interface USB 2.0 Device
Connector B4B-ZR
UVC Compliant No additional driver required
Operating Voltage DC 5V +/- 5%
Operating Current Maximum 300 mA
Operating Temperature -4°F-158°F (-20°C to 70°C)
Camera Board Size 38 mm x 38 mm x 16 mm (Hole Spacing: 34 mm x 34 mm, 28 mm x 28 mm)
Audio Single Microphone
Supported Operating System Windows, Linux, Android, and MAC
Sample Application Amcap Windows Camera Application for Video and Still Image Capture
UVC Controls Brightness, Contrast, Hue, Saturation, Sharpness, Gamma, White Balance (Auto), Backlight Contrast, Gain, Exposure (Auto)
Arducam 12MP USB Camera Module Package
Contents:
  • 1 x Arducam 12MP USB Camera Module with M12 Lens
  • 1 x USB Cable (1m)
  • 1 x Quick Start Guide
€ 74,95
Docs MYBOTSHOP documentation
