ArduCam 5MP OGO5B1B Mono Global Shutter USB 3.0 Camera
  • SKU: MBS-SES-185-40
  • Category: Sensors
  • Monochrome global shutter camera with high sensitivity, low noise, and enhanced NIR Performance
  • Resolution: 2592 × 1944, up to 25 fps at full Resolution
  • Low-distortion M12 lens for sharp, precise, and realistic image capture
  • Integrated proprietary ISP for advanced image enhancement
  • Plug-and-play; compatible with USB 2.0 and 3.0, no drivers required
The 5MP camera from Arducam’s USB 3.0 series is a high-performance monochrome global shutter camera, designed for superior image quality. With its high sensitivity, low noise, and optimized quantum efficiency (QE) in the near-infrared (NIR) spectrum, it delivers outstanding results, especially in low-light environments.
Offering a resolution of 2592 × 1944 pixels and up to 25 fps at full 5MP, it enables smooth and detailed video capture. The low-distortion M12 lens further ensures sharp, accurate, and realistic images.
Thanks to the integrated Image Signal Processing (ISP) – including debayering, gamma correction, and color optimization – the camera produces clear and precise results. It is ready to use right out of the box (plug-and-play) and works without additional drivers on both Windows and Linux. With USB 3.0, it reaches full performance while maintaining backward compatibility with USB 2.0.
Typical Applications
  • Mobile facial recognition
  • Stereo vision and structured light systems
  • Automatic identification & data capture (e.g., QR scanners, drones)
  • Smart home appliances
  • SLAM in robotics and smart home systems
  • High-performance sensor: monochrome global shutter with high NIR sensitivity and low noise
  • High resolution: 2592 × 1944 pixels at 25 fps – ideal for dynamic scenes without distortion
  • Precision optics: low-distortion M12 lens for sharp and natural image capture
  • Optimized image quality: ISP with debayering, gamma, and color correction for consistent results
  • Easy integration: plug-and-play for Windows/Linux, compatible with USB 2.0 & 3.0
Image Sensor
  • Sensor: OG05B1B
  • Still Resolution: 5MP
  • Color Filter Type: Mono
  • Shutter Type: Global Shutter
  • Optical Size: 1/2.53"
  • Output FormatYUY2
  • Pixel Size: 2.2 μmx 2.2 μm
  • Sensor Active Area: 2592 (H)×1944 (V)
  • Frame Rate (USB 3.0): 2592×1944@25fps
  • Frame Rate (USB 2.0): 2592×1944@5fps
Lens
  • Focus Type: Fixed Focus
  • Default Focus Range: 1m-∞
  • Lens Mount: M12 (S-mount)
  • F.NO: F2.8
  • E.F.L: 3.6mm
  • IR Sensitivity: No IR-cut filter, sensitive to IR
  • FOV: 95°(D)×82°(H)×66°(V)
USB Interface
  • Interface: USB 3.2 Gen 1 device, backward compatible with USB 2.0 hosts
  • ConnectorType-C reversible interface connector
  • UVC CompliantNo additional drivers required
Electrical and Mechanical
  • Operating Voltage5 V +/- 5%
  • Operating Temp.32°F-158°F (0°C to 70°C)
  • Power RequirementsMax: 1.5W
  • Camera Board Size34×34 mm
Functionality and Compatibility
  • Supported OS: Windows, Linux
  • Recommend Sample Application: PotPlayer for Windows, qv4l2 for Linux
  • UVC Controls: Brightness, Contrast, Gain, Exposure (Manual/Auto)
  • 1 x Arducam 5MP Mono USB3 Camera with Back Cover and Tripod Adapter
  • 1 x USB A to Type-C Cable (1m)
Enclosure
from
€ 434,95
  • Must be ordered. Ready for shipment in 7 days after order.
Docs MYBOTSHOP documentation
