ArduCam 64MP Autofocus Quad-Camera Kit for Raspberry Pi
- SKU: MBS-SES-256
- GTIN: 0618455044205
- HAN: B0402
- Category: Sensors
Manufacturers:
- Record up to four cameras simultaneously
- Single/Dual/Quad-Channel modes
- AF/Manual/Continuous AF
With this quad camera kit, up to four 64MP autofocus cameras can be used on a standard Raspberry Pi model. The ArduCam kit works by default in a four-channel mode, which means that all cameras are configured to take photos/videos at the same time.
Supported Modes
- Single channel (no synchronization): the four cameras work one after the other, with one camera recording one after the other. Full-res for everyone.
- Dual-Channel (synchronized): two cameras become a full-res frame, these work synchronously. 1/2 res for each.
- Quad channel (synchronized): all four cameras work in one full-res frame synchronous, 1/4 res for each.
- Optical Size: 1/1.7" (9,25mm diagonal (7,4x5,55mm))
- Focus Type: Manual/Auto
- Sensor Resolution: 9152 x 6944
- Video Mode (on Raspberry Pi): 1080p30, 720p60 and 640 x 480p60/90
- Video Mode (Camera Module): 1280x720@120fps, 1920x1080@60fps, 2312x1736@30fps, 3840x2160@20fps, 4624x3472@10fps, 9152x6944@2,7fps
- Color Filter: Quad Bayer Coding (QBC)
- Supported Plattforms ( full Resolution - 64MP): Pi 4B/CM4
- Supported Plattforms (superpixel Resolution - 16MP): Pi2/3/CM3/Zero W/Zero 2 W
- Raspberry Pi OS: Bullseye (32-bit/64-bit) (28.01.2022 or later Releases)
- Focus: 8cm ~ infinity
- Focal Ratio (F-Stop): F1.8
- Focal length: 5.1mm
- View Angle: 84° (diagonal)
- Dimensions: 25mm x 24mm
- Shutter Type: Rolling
- Output Format: JPEG/YUV/RGB/RAW10
- 4x 64MP Camera Module
- 1x UC-512 Camarray HAT
- 4x 30cm 15-22pin Camera cable
- 1x 7cm 15-22pin Camera cable
- 1x Screw pack
