Arducam 1080P Ultra Low Light 100° Wide Angle Camera Module
  • SKU: MBS-SES-185-48
  • GTIN: 05390368407166
  • HAN: B0635
  • Category: Sensors
  • Full HD for low light, 102° wide angle
  • USB 2.0 UVC, driver-free
The Arducam 1080P Ultra Low Light USB2 UVC Camera Module is a compact Full HD camera for low-light applications. Thanks to Nyxel® (near-infrared) and PureCel®Plus pixel technologies, it delivers low-noise images even at night. The wide-angle lens with an F1.0 aperture and a diagonal field of view of 102° captures a large image area.
The camera is UVC-compliant and connects via USB 2.0. It works on Windows, Linux and Android without additional drivers. Video is output in 1080p, 720p and smaller resolutions at 30 frames per second as MJPG, H.264 or YUV. Brightness, contrast, gamma, gain, sharpness, backlight and low-light compensation as well as exposure can be adjusted manually or automatically.
Typical applications include nighttime security, industrial machine vision, kiosk and vending systems, and medical imaging devices.
Manufacturer part number B0635
Resolution 2 MP, 1920 × 1080, color
Shutter Rolling shutter
Optical format / pixel size 1/2.8" / 2.9 µm × 2.9 µm
Output formats MJPG, H.264, YUV
Frame rates (MJPG / H.264) 1920 × 1080, 1280 × 720, 640 × 480, 320 × 240 @ 30 fps
Frame rates (YUV) 640 × 480, 320 × 240, 320 × 320, 128 × 128, 96 × 96 @ 30 fps
Lens M12-S, fixed focus, 3.9 mm focal length, F1.0
Field of view 102° (D) × 88° (H) × 47° (V)
Focus range 300 cm to infinity
IR filter Integrated 650 nm IR filter (visible light only)
Distortion TV: -10.4 %, F-θ: -32.0 %
Interface USB 2.0, UVC-compliant (driverless), B4B-ZR JST connector
Operating systems Windows, Linux, Android
Operating voltage / power consumption 5 V (± 5 %) / max. 1 W
Board size 38 × 38 × 1.6 mm
Weight 18 g
Operating temperature 0 to 50 °C
Storage temperature -20 to 85 °C
Certification RoHS
  • 1× Arducam 1080P Ultra Low Light USB2 UVC Camera Module (wide angle)
  • 1× USB 2.0 to B4B-ZR JST cable, 1 m
€ 94,95
Docs MYBOTSHOP documentation
