Arducam 2.2MP Mira220 RGB-IR Global Shutter USB3.0 Camera Evaluation Kit
- SKU: MBS-ARDU-07
- GTIN: 0658917512842
- HAN: EK035
- Category: Accessories
Manufacturers:
- Enhanced 2.2MP NIR global shutter image sensor for superior image quality.
- High frame rate of up to 80fps for capturing fast-paced scenes.
- USB 3.0 interface for easy integration with various hardware.
- User-friendly setup with no coding required, featuring SDKs and APIs.
- Ideal for low-light applications with high NIR sensitivity.
To help customers evaluate the cameras or build prototypes with their own circuits without dealing with fine pitch flex cables or soldering balls, Arducam has released the evaluation kit with camera breakout boards and Arducam USB2/USB3 camera shield without writing a single line of code.
The camera evaluation kit is based on the Mira220, an enhanced 1/2.7" 2.2MP NIR global shutter image sensor. Its rapid evaluation setup includes an immediately available camera and adapter kit, which, together with the Arducam USB Camera Shield UI tool, ensures a seamless integration experience for developers.
Capable of high frame rates up to 80fps, the Mira220 specializes in capturing fast-paced scenes with exceptional clarity. The USB 3.0 interface ensures compatibility with a wide range of hardware, providing flexibility for various applications. The addition of a low-distortion M12 lens enhances its adaptability to different imaging scenarios. Developers will appreciate the kit's user-friendliness, featuring developer-friendly SDKs and APIs for easy integration into existing projects. In addition, the Mira220 features high NIR sensitivity, making it ideal for applications that require enhanced performance in low-light conditions.
Applications
- Mobile Facial Authentication
- Active Stereo Vision/Structured Light Vision
- Automatic Identification and Data Capture (AIDC)/QR Readers/Drones
- Smart Wearable Devices
- SLAM for Robotics/Smart Home Appliances
- Enhanced Global Shutter CMOS: Built on Mira220's 2.2 MP sensor, excels in 2D/3D machine vision with global shutter and BSI technology, delivering superior image quality.
- Speedy Capture: Mira220 achieves a maximum frame rate of 80 fps, enabling real-time imaging for dynamic applications.
- Low-Distortion M12 Lens: Enhanced with a high-res M12 lens, ensuring crisper images.
- High NIR Sensitivity: With a 2.79 μm pixel size, the sensor ensures high sensitivity, ideal for challenging lighting conditions.
- Effortless Integration: The camera & adapter bundle, paired with a USB 3.0 interface, offers quick evaluation, seamless integration, and user-friendly adjustments for diverse applications.
Specifications
- Sensor: Mira220
- Resolution: 2.2MP
- Color Filter Type: RGB-IR
- Shutter Type: Global Shutter
- Optical Size: 1/2.7"
- Sensor Output Format: RAW12 (RGB-IR)
- Pixel Size: 2.79μm x 2.79μm
- IR Sensitivity: Without IR-cut Filter
- Active Sensor Area: 1600(H) × 1400(V)
- Frame Rate: 1600x1400@30fps, 640x480@80fps
- Exposure Control Range: 12μs-33333μs
- Gain Control Range: Not Supported
Package Including
- 1 x Mira220 RGB-IR USB3 Camera Evaluation Kit with Back Cover and Tripod Adapter
- 1 x 1M USB Cable
