Arducam 5MP Fixed Focus USB 3.0 Camera Evaluation Kit
  • SKU: MBS-SES-353
  • GTIN: 0658917514327
  • HAN: EK038
  • Category: Sensors
  • Quick Evaluation
  • 5MP high resolution: Active pixels: 2592(H) × 1944(V)
  • USB 3.0 interface
  • Fixed focus: Focus distance: 60 cm ~ Infinity
  • SDK & API
Arducam provides a practical solution for rapid camera evaluation and prototype development with its evaluation kit, eliminating the need for complex soldering or fine pin-pitch flex cables. Thanks to the camera breakout boards and the Arducam USB2/USB3 camera adapter, the system can be used immediately without any programming.
The kit is based on a high-resolution 5MP image sensor and a fixed-focus lens. In combination with the Arducam USB Camera Shield UI tools, users can adjust white balance, exposure, gain, and other parameters as needed.
With the included 5MP camera module and USB 3.0 camera adapter, users can quickly build prototypes and conduct feasibility studies—regardless of the hardware they are using. Additionally, a comprehensive SDK is provided, enabling easy integration into machine vision systems. Arducam is committed to delivering innovative and user-friendly camera Solutions.
Applications
  • Smartphones
  • Toys & Tablets
  • Machine Vision
  • ARM/FPGA/DSP Platforms
  • Prototyping & Product Development
5MP Resolution: Captures high-quality, detailed images.
Fixed-Focus Camera Module: Ensures consistent image sharpness.
USB 3.0 Interface: Enables fast and reliable data transmission.
Wide Field of View (88° DFoV): Captures larger scenes in every frame.
Complete Plug-and-Play Kit: Includes camera and adapter for easy setup and Evaluation.
  • Resolution/Frame Rate: 2592x1944@6fps,1920x1080@6fps, 1600x1200@6fps, 1280x720@25fps, 640x480@30fps,320x320@30fps, 320x240@30fps,128x128@30fps, 96x96@30fps
  • Sensor Output Format: JPG/YUV/RGB
  • Exposure Control Range: -
  • Gain Control Range: -
  • Focus Control Range: -
  • Focal Length: 2.46
  • Field of View(FOV): 88°(D)×75(H)×60°(V)
  • F.NO: F2.0±5%
  • Focus Type: Fixed Focus
  • Power Consumption*: Max: 5V/338mA
  • Operation Temperature: 0-50 ℃
  • Evaluation Kit Size: 40mmx40mm
Functions
  • Image File Format: -
  • Software ISP: -
  • Supported Programming Languages: Python/C++
  • Supported OS: Windows x86/x86_64
  • GUI(Graphical User Interface): Supported
  • 1 x Arducam 5MP USB3 Camera Kit with Back Cover and Tripod Mount
  • 1 x USB3.0 Cable
Notes
  • Contains small components – keep away from children to avoid choking hazards.
  • After receiving the package, please verify that all included items match the product description.
  • Specific configuration files are required to use the camera kit with the Arducam USB Camera Shield GUI. Please contact sales to obtain these files.
€ 355,95
Docs MYBOTSHOP documentation
