AverMedia SenseEdge Development Kit
  • SKU: MBS-SES-228
  • GTIN: 0658917504878
  • HAN: SenseEdge Development Kit
  • Category: Sensors
  • Fully integrated AI vision platform
  • Robust GMSL/FAKRA transmission with up to 15 m range
  • IP65 protection and vibration resistance
  • Pre-installed software environment (NVIDIA JetPack BSP, RealSense™ SDK 2.0, AVerMedia SDK)
The AVerMedia SenseEdge Development Kit (GMSL Series) is a fully integrated, ready-to-use AI vision platform that helps developers and engineering teams turn ideas into deployable systems quickly and efficiently. It combines the AVerMedia D317 NVIDIA® Jetson™ AGX Orin carrier board, a GMSL camera adapter board, and the RealSense™ D457 GMSL/FAKRA depth camera into a single, pre-validated system.
The GMSL Series is purpose-built for robots, autonomous mobile robots (AMRs), and outdoor deployments, transmitting low-latency video via Power-Over-Coax (PoC) — stable and vibration-resistant over cable lengths of up to 15 m. The RealSense™ D457 camera features an IP65-rated enclosure, a global shutter sensor, integrated IMU, and the GMSL/FAKRA interface with 6 Gbit/s bandwidth. NVIDIA JetPack BSP, RealSense SDK, and AVerMedia SDK come pre-installed and are ready to use out of the box.
Technical Data
Platform
Carrier Board AVerMedia D317 (NVIDIA® Jetson™ AGX Orin)
Camera Adapter GMSL adapter board (2x Mini FAKRA, up to 8x GMSL cameras via FAKRA cable, PoC)
Software (pre-installed) NVIDIA JetPack BSP, RealSense™ SDK 2.0, AVerMedia SDK
RealSense™ D457 Depth Camera
Interface GMSL / FAKRA
Depth Technology Stereoscopic
Depth Output Resolution Up to 1280 × 720
Depth Frame Rate Up to 60 fps
Depth Field of View (H × V) 87° × 58°
Depth Accuracy < 2% at 4 m
Minimum Depth Distance (Min-Z) ~ 52 cm
Ideal Range 0.6 m – 6 m
RGB Resolution 1280 × 800 @ 30 fps (1 MP)
RGB Field of View (H × V) 90° × 65°
RGB Sensor Global Shutter
IMU Integrated
Protection Rating IP65
Camera Module RealSense™ D450 + Vision Processor D4 Board V5
Cable Length (GMSL) Up to 15 m (coaxial cable)
Mounting 1/4"-20 UNC thread
Camera Dimensions (L × D × H) 124 × 26 × 36 mm
Operating Environment Indoor & Outdoor
Scope of Delivery
  • 1x AVerMedia D317 carrier board (NVIDIA® Jetson™ AGX Orin)
  • 1x GMSL camera adapter board
  • 1x RealSense™ D457 GMSL/FAKRA depth camera
  • 1x GMSL coaxial cable (FAKRA)
  • 1x Tripod
  • 1x Quick start guide
€ 3.704,95
