Clearpath Robotics Husky A300 Battery Upgrade: 120Ah
  • SKU: MBS-Z-333
  • GTIN: 0658917513450
  • Category: Accessories
  • Extended operating time
  • Battery type: LiFePO₄
  • Capacity: 120 Ah at 25.6 V
  • Charging time: approx. 10-12 hours (standard charger)
  • Operating time: up to 12 hours with typical use
The Clearpath Robotics Husky A300 120 Ah Battery Upgrade is a high-capacity energy enhancement designed for the Husky A300 Unmanned Ground Vehicle (UGV). With a capacity of 120 Ah at 25.6 V, this lithium iron phosphate (LiFePO₄) battery significantly extends the operational runtime, making it ideal for demanding applications that require prolonged energy supply.
This 120 Ah battery upgrade provides the maximum runtime currently available for the Husky A300, making it especially suitable for extended missions, high-power payloads, or heavy-duty research and industrial Tasks.
This upgrade transforms the Husky A300 into a high-endurance platform suitable for research, industrial applications, and long-duration autonomous operations.
  • Battery Type: LiFePO₄ (Lithium Iron Phosphate)
  • Charging Time: Approximately 10–12 hours (standard charger)
  • Operational Runtime: Up to 12 hours under typical usage
  • Standby Time: Up to 45 hours
  • Compatibility: Direct replacement for the standard 40 Ah battery or 80 Ah upgrade
  • Protection Rating: IP54 (splash-resistant)
  • Operating Temperature Range: –20 °C to +40 °C
Benefits of the 120 Ah Battery Upgrade
  • Maximum Runtime: Extends operational time significantly compared to standard or 80 Ah batteries, ideal for long missions or continuous operation.
  • High Power Support: Provides ample energy for demanding applications, including manipulators, LiDAR, additional sensors, or other high-power peripherals.
  • Optimized Charging: Compatible with high-power chargers (e.g., Delta-Q IC650 or High Power Expansion Kit) for efficient and safe charging.
  • Future-Proof: Supports advanced applications and additional energy requirements for new payloads.
Installation & Usage Notes
  • Installation: Recommended to select the 120 Ah battery at the time of purchase, as post-purchase user installation may require professional assistance.
  • Charger Compatibility: Use the supplied charger or an optional High Power Expansion Kit to maximize charging efficiency.
  • Maintenance: Regular inspections for physical damage or wear are recommended to maintain battery performance and longevity.
€ 6.709,95
