Clearpath Robotics Husky A300 High Power Charger (650W)
  • SKU: MBS-Z-330
  • GTIN: 0658917513429
  • Category: Accessories
  • Output voltage: 27.7 V DC
  • Output current: approx. 23.5 A
  • Protection class (housing): IP66 (suitable for outdoor use)
Technical data – High Power Charger (650 W) for Husky A300
  • Charger Model: Delta-Q IC650 (650 W)
  • Output Voltage: 27.7 V DC
  • Output Current: approx. 23.5 A
  • Enclosure Protection: IP66 (suitable for outdoor use)
  • Usage: Indoor & Outdoor (with limitations – AC cable must be protected outdoors)
Additional Operating Notes
  • The 650 W charger is the upgraded, wired charging option for the Husky A300.
  • It uses the same LED charging patterns as the larger 1200 W upgrade charger.
  • Suitable for indoor and outdoor use; however, the AC cable should be shielded from rain or moisture when used outdoors (e.g., under a cover).
Advantages & Benefits
  • Higher charging power enables significantly faster charge times compared to the standard charger.
  • Especially useful in operations where minimal downtime is critical.
  • Supports larger battery options for the Husky A300 (e.g., upgrade or extended batteries), ensuring efficient charging for these higher-capacity batteries.
€ 1.949,95
