Holybro DroneCAN H-RTK F9P Rover with 27cm cable
  • flatter profile and higher water resistance
  • Dual band patch antenna
  • update rate: up to 8Hz
  • robuster than UART
Holybro's DroneCAN H-RTK F9P is the latest high-precision GNSS positioning system. The same DroneCAN protocol was used here.
General Features
  • Multiband RTK with fast convergence times, reliable performance, simultaneous GPS reception, GLONASS, Galileo and BeiDo, fast update rate for high dynamic and large scale applications with centimeter precision
  • update rate: up to 8Hz for navigation, updateability, noise immunity, real-time functions
  • increased resistance to electromagnetic interference > more robust than UART
  • No occupancy of serial ports of the flight controller
  • Possibility to connect multiple CAN devices to the same CAN bus via a hub
  • Use of a U-Blox F9P.module, MM150 compass and a three-color LED display
  • Equipped with: STM32GB processor with 170 MHz, 512 KByte Flash and 96 KByte RAM
  • Supports updating of DroneCAN firmware via DroneCAN GUI tool
  • Compatible with Pixhawk series open source flight controllers
Features F9P Rover
  • flat profile
  • higher water resistance
  • dual band patch antenna (+integrated connection cable to CAN bus)
  • excellent for indoor applications with few obstructions
Features F9P Helical
  • spiral antenna
  • Suitable for rooms with obstacles
  • Attachment: either directly to the module or via an SMA cable
  • UART2 connector, through which YAW/Heading (Moving Baseline) can be performed
  • Can be used on rover (aircraft) or as base station
  • As base station: RTK communicates via USB with ground control station, DroneCAN protocol is not used > Use of a standard H-RTK F9P Helical or Base
DroneCAN H-RTK F9P Helical
Intended Application
Rover (aircraft) only
Rover (aircraft) or Base station
GNSS Receiver
U-blox ZED-F9P high precision GNSS module
Antenna
Ceramic Patch Antenna with 20dB LNA
Helical Antenna with 36dB LNA
Processor
STM32G473
STM32G473
Magnetometer
BMM150
BMM150
GNSS
BeiDou, Galileo, GLONASS, GPS / QZSS
GNSS Band
B1I, B2I, E1B/C, E5b, L1C/A, L1OF, L2C, L2OF
Positioning accuracy
3D FIX: 1.5 m / RTK: 0.01 m
Communication Protocol
DroneCAN 1Mbit/s
DroneCAN 1Mbit/s
Antennas Peak Gain (MAX)
L1: 4.0dBi
L2:1.0 dBi
L1: 2dBi
L2: 2dBi
Time-TO-First Fix
Cold start: ≤29s
Hot start: ≤1s
Cold start: ≤25s Hot start: ≤1s
Navigation Update Rate
RAW: 20Hz Max RTK: 8Hz Max
Moving Base RTK: 5Hz Max
Cable Length
27cm or 50cm
N/A
Antenna Connection Type
N/A
Board: SMA female Antenna: SMA male
Working voltage:
4.75V~5.25V
4.75V~5.25V
Current Consumption
~250mA
~250mA
Dimensions
Diameter: 80mm Height: 20mm
Board: 51.1*35*22.9mm Antenna Diameter: 27.5mm Antenna height: 59mm
Weight
123g
58g
Operating Temperature
-20°C to 85°C
-20°C to 85°C
  • DroneCAN H-RTK F9P with 27cm cable
€ 559,95
Docs MYBOTSHOP documentation
