Holybro Remote ID without case
  • SKU: MBS-SES-292-01
  • GTIN: 0658917502379
  • HAN: 18089A
  • Category: Sensors
Holybro Remote ID
  • cheap, small, light
  • FCC- and CE- certified
  • Open-Source-firmware
  • Supported in PX4 & Ardupilot
Holybro's Remote ID Module is a low-cost, lightweight, small form factor module that sends information about UAVs in flight via Bluetooth and WiFi. It will CAN and other serial protocols. This radio module is also FCC and CE certified. It runs open source firmware (ArduRemoteID), providing what is known as a Standard-Remote-ID-solution. This is primarily aimed at drone manufacturers and system Integrators.
Note: Primarily directed at drone manufacturers and system integrators, as you will need to complete your own certification process with the FAA (DoC facility) if you are located in the US.
  • Radio module
    • Espressif ESP-C3 module
    • Bluetooth ans WiFi 2,4GHz (ERP): +20 dBm (100 mW)
    • FCC & CE certified
  • Firmware
  • Protocol: CAN and Serial
  • Interface
    • 1x JST GH 4pin CAN  (CAN) port
    • 1x JST GH 6pin TELEM (UART) port
  • Antenna Connector type
    • on CNC Case: SMA connector
    • on PCB: IPEX connector
  • Range: >5km detection range (depends on many factors such as the receiver antenna gain, transmission protocol, weather conditions, flying height, receiver height line of sight etc. With professional receivers a range of 5 km and more is possible.)
  • Power: 5V supplied from TELEM or CAN port
  • LED Lights: bright RGB Status LED
  • Size
    • without case: 35,3 x 23,5 mm (not incl. antenna)
    • with CNC case: 38 x 26,5 x 11,5 mm (not incl. antenna)
  • Mount: M2 screws
  • Operating temperature: -40°C to +85°C
  • Weight
    • PCB only: 4g
    • with CNC case and antenna: 27,5g
    • without case and antenna: 16,5g (cable: 20cm)
  • Certification: FCC & CE
  • 1x Remote ID
  • 1x Antenna
  • 1x JST GH 4pin 150mm cable
  • 1x JST GH 6pin 150mm cbale
Shipping weight: 0,50 kg
Item weight: 0,03 kg
€ 29,95
Docs MYBOTSHOP documentation
