Holybro PX4 Development Kit X500 V2 (433MHz Telemetry Radio)
  • SKU: MBS-DR-14
  • GTIN: 0658917599911
  • HAN: 30154
  • Category: Drones
The Holybro X500 V2 Full Kit-Pixhawk6C (433MHz Telemetry Radio)
  • Holybro Pixhawk 6C Flight Controller
  • M10 GPS
  • Plug & Play SiK Telemetry Radio
The Holybro X500 V2 ARF Kit is a carbon fiber drone kit that can be assembled in a short time (about 15 minutes).
Due to the overwhelming popularity of its predecessor, the X500 Kit, we have put together this kit consisting of the following components:
  • X500 V2 frame incl. motors, ESC's & proppeller
  • Pixhawk PX4 Flight Controller
  • M10 GPS Module
  • PM02 Power Module
  • 433MHz 100mW Telemetry Module
1. X500 V2 frame kit.
  • Body: full carbon top and bottom plate (144x144 mm, 2 mm thick).
  • Arm: 16 mm carbon fiber tubes with fiber reinforced nylon connectors
  • Chassis: 16 mm and 10 mm diameter carbon fiber tubes with improved and reinforced plastic tees
  • Platform board: mounting holes for GPS and companion computers like Raspberry Pi 4 and Jetson nano
  • dual 10 mm diameter rod
  • 250 mm long rail mounting system
  • Battery holder (with 2 battery straps)
  • hand tool (for installation)
2. X500 V2 ARF Kit
  • X500 V2 frame kit
  • Pre-installed elements 4x motors - Holybro 2216 KV920 motor.
    • 4x controller - BLHeli controller
    • 6x 1045 propeller
    • Power Distribution Board - XT60 connector for battery & XT30 connector for controller & peripherals.
Mechanical data
  • wheelbase: 500 mm
  • motor mount pattern: 16x16 mm
  • frame body: 144x144 mm, 2 mm thick
  • chassis height: 215 mm
  • distance between upper and lower plate: 28 mm
  • weight: 610 g
  • Flight time: ~18 minutes hover with no additional payload. Tested with 5000mAh Battery
  • Max payload: ~1kg (w/ 4S 5000 mAh battery @70% Throttle)
Shipping weight: 2,00 kg
Item weight: 1,40 kg
Flight controller
from
€ 899,95
