Intel® RealSense Depth Camera D415 Incl. USB cable and tripod
  • SKU: MBS-SES-138-02
  • GTIN: 5032037110273
  • HAN: 82635ASRCDVKHV 961443
  • Category: 3D Machine Vision
Intel® RealSense™ Depth Camera D415
  • up to 1920 x 1080 RGB resolution
  • diagonal field of view over 70°
  • range 0.3 m to over 10 m (varies depending on lighting conditions)
Software
  • up to 1920 x 1080 RGB-Resolution
  • FOV: 70°
  • Range: 0,3 - 10m (Depending on lightning conditions)
  • Intel RealSense D415 Depth Camera
  • Tripod
  • USB-Cable
Shipping weight: 0,30 kg
Item weight: 0,29 kg
Datasheet D400 Series
Equipment
€ 379,96
