Intel® RealSense Depth Camera D435i incl. accessories
  • SKU: MBS-SES-141-02
  • GTIN: 5023037148399
  • HAN: 82635D435IDK5P 999AFR
  • Category: 3D Machine Vision
Intel® RealSense™ Depth Camera D435i
  • up to 1920 x 1080 RGB resolution
  • range 0.2 m to over 10 m (varies depending on lighting conditions)
  • Includes Inertial Measurement Unit (IMU) for 6 degrees of freedom (6DoF)
Software
  • up to 1920 x 1080 RGB-Resolution
  • FOV: 90°
  • Range: 0,2 - 10m (Depending on lightning conditions)
  • integrated IMU with 6DOF#s
  • Intel RealSense D435i Depth Camera
  • Tripod
  • USB-Cable
Shipping weight: 0,31 kg
Item weight: 0,20 kg
Accessories
€ 454,03
