Intel® RealSense Depth Camera D435
Intel® RealSense™ Depth Camera D435
  • up to 1920 x 1080 RGB resolution
  • range 0.2 m to over 10 m (varies depending on lighting conditions)
Software
  • up to 1920 x 1080 RGB-Resolution
  • FOV: 90°
  • Range: 0,2 - 10m (Depending on lightning conditions)
  • Intel RealSense D435 Depth Camera
  • Tripod
  • USB-Cable
Shipping weight: 0,31 kg
Item weight: 0,10 kg
Datasheet D400 Series
Accessories
from
€ 419,99
  • Available immediately
