Intel® RealSense Depth Camera D435f camera only
  • SKU: MBS-SES-258-01
  • GTIN: 0618455047794
  • HAN: 82635D435FDKMP 99ANHL
  • Category: 3D Machine Vision
Intel® RealSense™ Depth Camera D435
  • IR pass filter
  • up to 1920 x 1080 RGB resolution
  • range 0.2 m to over 10 m (varies depending on lighting conditions)
Software
Thanks to IR now with improved depth quality
The Intel® RealSense™ D435f depth camera expands the RealSense portfolio for the growing autonomous mobile robot market. The IR pass filter significantly improves the quality of depth noise, as well as the performance range for many robotic environments.
  • IR pass filter
  • up to 1920 x 1080 RGB-Resolution
  • FOV: 90°
  • Range: 0,2 - 10m (Depending on lightning conditions)
  • USB-C* 3.1 Gen 1 connector
  • Dimensions 90 * 25.8 * 25 mm
  • Intel RealSense D435 Depth Camera
Shipping weight: 0,31 kg
Item weight: 0,30 kg
Datasheet D400 Series
€ 429,95
Others also bought:
