Intel® RealSense Depth Camera D457 incl. accessories
  • SKU: MBS-SES-305-02
  • GTIN: 0658917502850
  • HAN: 82635DSD457 99AVPN
  • Category: 3D Machine Vision
  • IP 65 Certified
  • GMSL/FAKRA interface
  • up to 1280 x 800 RGB resolution
  • RGB global shutter sensor for up to 90 frames/s
  • range 0.4 m to over 10 m (varies depending on lighting conditions)
  • Includes Inertial Measurement Unit (IMU) for 6 degrees of freedom (6DoF)
Software
Technical Details
  • IP 65 Certified
  • GMSL/FAKRA(Z-Code) interface
  • up to 1280 x 800 RGB-Resolution
  • FOV: 90°
  • RGB Global Shutter frames up to 90 Pictures/Sec.
  • Range: 0,4 - 10m (Depending on lightning conditions)
  • integrated IMU with 6DOF#s
Delivery content
  • Intel RealSense D457 Depth Camera
  • Tripod
  • USB-Cable
Shipping weight: 0,38 kg
Datasheet D400 Series
Accessories
€ 611,95
