Jackal Wibotic RX Coil Integration
  • SKU: MBS-Z-456
  • GTIN: 05390368407173
  • HAN: 023752
  • Category: Accessories
  • Wireless charging: The Jackal charges automatically as soon as it drives over the charging station
  • Fully integrated: OC-150 charge controller in the vehicle, receiving coil housed externally in an IP66-rated enclosure
  • Requires the WiBotic TR-302 Edge Transmitter (not included)
The Jackal Wibotic RX Coil Integration prepares your Clearpath Jackal platform for wireless charging with WiBotic. The robot charges its battery as soon as it drives over the charging station, with no plug connection or manual intervention. This makes it ideal for autonomous long-term operation, patrols and recurring inspection runs.
The option covers the complete integration of the WiBotic OC-150 onboard charger and the receiver coil on the Jackal. The charger is installed inside the vehicle, while the coil enclosure sits on the outside of the chassis and is protected against dust and powerful water jets to IP66. Custom mounting plates and a custom battery cable ensure a clean installation tailored to the vehicle.
Operation additionally requires the WiBotic TR-302 edge transmitter as the charging station. It is not included in the scope of delivery.
Product WiBotic charging receiver for Clearpath Jackal, incl. integration
Onboard charger WiBotic OC-150, installed inside the vehicle
Receiver coil Coil enclosure mounted on the outside of the chassis
Coil enclosure protection rating IP66
Required charging station WiBotic TR-302 edge transmitter (not included)
  • 1× coil enclosure assembly
  • 1× WiBotic OC-150 onboard charger
  • Custom mounting plates
  • Custom battery cable
  • Complete integration on the Jackal incl. documentation
Note: The WiBotic TR-302 edge transmitter is mandatory for charging and must be ordered separately.
Individual purchase: If the components are purchased individually, i.e. without this integration option, installation on the Jackal is carried out by the customer.
€ 4.109,95
