Lightware communication and power cable for SF11, SF30, SF45
  • SKU: MBS-Z-364
  • GTIN: 0658917505035
  • HAN: CAB_195
  • Category: Accessories
Lightware communication/power cable for SF11, SF30, SF45
  • Length: 35 cm
The LightWare LW 000_135 (Main Cable Type 1) is the communication and power cable (350 mm) for the LightWare SF11, SF30 and SF45 sensors. It is the standard connection cable for these sensors and is also available as a spare/accessory cable.
The cable carries the power supply and the serial communication signals (RX/TX) and connects to the sensor via a connector; the free ends are stripped and tinned for integration into your system. The wire colours are fixed and must not be deviated from to ensure correct pin assignment.
In combination with the LightWare DroneCAN adapter, the LW 000_135 serves as the matching connection cable between the adapter and the SF30 sensor.
Technical specifications
Type Communication and power cable (Main Cable Type 1)
Length 350 mm (35 cm)
Compatible with SF11, SF30, SF45
Connection connector on the sensor side; free ends stripped and tinned
Transmitted signals power supply (+5 V, GND), serial communication (RX/TX)
Wiring fixed wire colours (do not deviate)
  • 1× LightWare LW 000_135 communication and power cable (350 mm) for SF11 / SF30 / SF45
Shipping weight: 0,30 kg
Item weight: 0,20 kg
€ 17,99
