Livox Mid360S/AVIA2 TTL / GPS Time Sync & Data Connector cable 5m
- SKU: MBS-Z-441-07
- GTIN: 0658917505066
- HAN: 5M M12 1 to 3 Wire
- Category: Accessories
Manufacturers:
Livox Connector cable Mid360S/AVIA2 M12 1 to 2
- Data connection: RJ45 plug
- PVC-shielded
This connection cable links compatible Livox lidar sensors to network and power via an M12 12-pin connector (female). Plugged in on the sensor side, it splits into an RJ45 connector for the data link and a separate power cable.
The main line is a shielded PVC cable, the network wire a shielded PVC cable of category Cat5E, and the power wire an unshielded PVC cable. With IP67 protection the cable is dust-tight and protected against temporary immersion – making it suitable for outdoor use and harsh environments.
Compatible lidar models
- Livox AVIA
- Livox HORIZON
- Livox MID-360
- Livox Mid-70
Technical specifications
| Sensor connector | M12 connector, 12-pin (female) |
| Data connector | RJ45 connector |
| Main line | PVC, shielded |
| Network wire | PVC Cat5E, shielded |
| Power wire | PVC, unshielded |
| Protection rating | IP67 (waterproof) |
- 1× Livox connection cable with M12 12-pin connector (female), RJ45 connector and power cable
| Item information | Value |
| Item weight: | 0,21 kg |
