Livox Mid360S/AVIA2 TTL / GPS Time Sync & Data Connector cable 10m
  • SKU: MBS-Z-441-09
  • GTIN: 0658917505080
  • HAN: 10M M12 1 to 3 Wire
  • Category: Accessories
Livox Connector cable Mid360S/AVIA2 M12 1 to 2
  • Data connection: RJ45 plug
  • PVC-shielded
This connection cable links compatible Livox lidar sensors to network and power via an M12 12-pin connector (female). Plugged in on the sensor side, it splits into an RJ45 connector for the data link and a separate power cable.
The main line is a shielded PVC cable, the network wire a shielded PVC cable of category Cat5E, and the power wire an unshielded PVC cable. With IP67 protection the cable is dust-tight and protected against temporary immersion – making it suitable for outdoor use and harsh environments.
Compatible lidar models
  • Livox AVIA
  • Livox HORIZON
  • Livox MID-360
  • Livox Mid-70
Technical specifications
Sensor connector M12 connector, 12-pin (female)
Data connector RJ45 connector
Main line PVC, shielded
Network wire PVC Cat5E, shielded
Power wire PVC, unshielded
Protection rating IP67 (waterproof)
  • 1× Livox connection cable with M12 12-pin connector (female), RJ45 connector and power cable
Item weight: 0,35 kg
Length
€ 139,95
Docs MYBOTSHOP documentation
