MAB Robotics Absolute Output Encoder
MAB Absolute Output Encoder
  • Resolution: 14 Bit
  • Main Applications: Quadruped and Legged Robots, Exoskeletons, ROV, UGV, Drone
MAB-Absolute-Output-Encoder
The MAB Absolute Output Encoder is an expansion module specifically designed for the MD80 V2.0 controller. Its main function is precise positioning of geared motors after commissioning. Additionally, it enables direct control of the output shaft and reporting of position and velocity values. The encoder is versatile, functioning in both central and off-axis scenarios.
  • Dimensions: 19 mm x 12 mm x 6 mm
  • True absolute measurements
  • Accuracy: 0.3° for axial configuration, up to 1.0° for off-axis configuration
  • Set includes: 15 cm cable and magnet
  • Maximum cable length: 1 m
Main applications: Quadruped and legged robots, exoskeletons, ROVs, UGVs, drones, mobile indoor robots, wheel platforms, and cobots.
The MAB Absolute Output Encoder is particularly suitable for applications in various robotics fields, including quadruped and legged robots, exoskeletons, ROVs (Remotely Operated Vehicles), UGVs (Unmanned Ground Vehicles), drones, mobile indoor robots, wheel platforms, and cobots (collaborative robots). Due to its cost-effective, small, and compact design, the encoder can be easily integrated into various mobile robotics applications.
€ 54,95
