MANUS Metagloves Pro - Top Modules
- SKU: MBS-Z-450
- GTIN: 05390368407173
- HAN: 300122
- Category: Accesoires
Manufacturers:
- USB 2.0 Type-C
- Up to 3 hours of continuous operation
- Sampling rate: 120 Hz
MANUS Metagloves Pro – Top Modules
The Top Modules are the electronics unit of the MANUS Metagloves Pro. They contain all of the sensing and wireless technology and attach to the Sensor Gloves in a single step via an integrated latch. They are supplied as a pair for the left and right hand.
Because the Top Modules detach from the glove, one set of electronics can be shared by several users – each with their own well-fitting Sensor Gloves. This makes it cost-effective to equip labs, studios and training rooms without buying a complete system for every person. The Top Modules are also ideal as a replacement if the electronics are damaged, instead of having to replace the entire set.
Your benefits at a glance
- One module, many users: one set of Top Modules for several users with their own Sensor Gloves
- Quick change: attaches to the glove in one step via integrated latch
- Wireless or wired: Bluetooth via the MANUS Wireless Dongle or USB-C
- Uninterrupted operation: swappable batteries with up to 3 hours of runtime, optional continuous operation via USB-C
- Clear status indication: battery and status LEDs directly on the module
- Long warranty: 24-month manufacturer warranty from delivery
Technical specifications
| Compatible with | MANUS Metagloves Pro Sensor Gloves (XS, S, M, L) |
| Sampling rate | 120 Hz |
| Motion-to-data latency | 30 ms wired, 50 ms wireless |
| Wired connection | USB 2.0 Type-C |
| Wireless connection | MANUS Wireless Dongle (USB 2.0 Type-A), Bluetooth 5.0 |
| Wireless range | up to 15 m, depending on environment |
| Extended range | with MANUS Bodypack Lite |
| Battery | swappable, snap-fit locking |
| Battery life | up to 3 hours of continuous use |
| Charging time | approx. 2 hours |
| Charging | installed battery via USB-C (5 V / 0.5 A) or MANUS Charging Station |
| Status indication | Battery LED and status LED |
| Hand module dimensions (H × W × D) | 60.7 × 78.2 × 34.3 mm |
| Wireless dongle dimensions | 27.8 × 70.3 × 8.5 mm, cable length 43 cm |
| Software | MANUS Core 3.0 or higher |
- 1× pair of MANUS Metagloves Pro Top Modules (left and right)
- 2× battery
- 1× MANUS Wireless Dongle
Note: Sensor Gloves not included – available separately in sizes XS, S, M and L. Not compatible with the Sensor Gloves of the Metagloves Pro Haptic.
