MANUS Sensor Gloves for Metagloves Pro
  • XS, S, M or L
  • a good fit, washable
The Sensor Gloves are the textile gloves of the MANUS Metagloves Pro – the part worn directly on the hand that carries the five EMF fingertip sensors. All electronics are housed in the detachable Top Module, which clips onto the glove in a single step.
The Sensor Gloves enable the modular “one Top Module, many users” concept: instead of purchasing a second complete system, each user gets their own well-fitting, washable glove. This is hygienic, cost-efficient and ensures precise data, because the fingertip sensors only align exactly with the fingertips when the size is right. Thanks to persistent calibration profiles, no recalibration is needed when switching between users or gloves.
Your benefits at a glance
  • Multi-user operation: one set of Top Modules for several users – each with their own glove
  • Accurate fit: available in several sizes so the sensors sit exactly on the fingertips
  • Hygienic: textile washable once the electronics have been removed
  • Clean setup: sensor cables fully integrated and protected inside the textile
  • Quick change: Top Module attached in one step via integrated latch
  • Replacement for wear: ideal as a spare part for intensive continuous use
Compatible with MANUS Metagloves Pro (Top Modules)
Glove type Full-finger glove
Fingertip sensors 5 EMF sensors with 6-DoF tracking (3-axis position, 3-axis rotation)
Sampling rate 120 Hz
Sensor placement Integrated in the glove textile, removable from the textile
Sensor cables Fully integrated and enclosed
Fingertip sensor dimensions 20.3 × 14.6 × 9.6 mm
Top Module attachment Integrated latch, 1 step
Sizes XS, S, M, L
Material 72 % polyester, 28 % spandex
Washability Yes, with electronics removed
Manufacturer part numbers 300106 (XS), 300100 (S), 300104 (M), 300105 (L)
  • 1× pair of MANUS Sensor Gloves for Metagloves Pro (left and right), in the selected size
Note: Textile sensor gloves only – without Top Modules, batteries or wireless dongle. Operation requires an existing MANUS Metagloves Pro set. Not compatible with the Top Modules of the Metagloves Pro Haptic.
Size
€ 1.549,95
Docs MYBOTSHOP documentation
