MAUCH PL Sensor Board incl. CFK housing
MAUCH PL Series
  • Pixhawk voltage & current monitoring
  • Voltage: 85V (20S)
  • Current: 50 - 200A (version dependent)
  • Easy integration with Ardupilot & PX4
The MAUCH PL (Premium Line) series describes sensor modules for an input voltage of up to 85V (20S) with a current between 50-200A.
Due to the easy integration into Ardupilot, the voltage & current sensor is very popular with users of the ProfiCNC/Hex-Aero products, such as the Black & Orange Cube Standard Set. The PL-XXX is connected with a PL BEC or MAUCH Sensor Hub X2-V2 to the power input of the flight controller.
Technical Data
  • Without cover: 27,5  x 19,5 x 10,5mm / 17g
  • With cover: 43,5 x 23 x 15mm / 22g
  • MAUCH PL-XXX Sensor Board
Shipping weight: 0,05 kg
Item weight: 0,02 kg
from
€ 66,95
  • Available immediately
