MAUCH 010 PL Sensor Hub X2 + CFK
MAUCH Sensor Hub
  • Monitoring of two Sensor Boards
  • Current & voltage monitoring
  • Uniform discharge of two batteries
MAUCH 010 = PL Sensor Boards (001-004)
MAUCH 080 = HS Sensor Boards (071-076)
The MAUCH Sensor Board is designed to connect two Sensor Boards and monitor the current & voltage of the batteries. The Sensor Board is connected to the alarm I/O of the FC/Pixhawk and alerts the pilot immediately if there is a difference of 15%, so that the pilot can immediately carry out the landing or check the batteries.
The following components are required to build the system described above:
  • 1x sensor hub X2
  • 2x Current sensor board:
    PL-050 =   2x50A = 0-100A Total
    PL-100 = 2x100A = 0-200A Total
    PL-200 = 2x200A = 0-400A Total
  • 1x MAUCH PL BEC
  • MAUCH 010 Sensor hub X2
  • Connection cable
Shipping weight: 0,03 kg
Item weight: 0,02 kg
€ 79,99
