Makera Carvera CNC Machine
  • Automatic tool change
  • High precision and versatility
  • Built-in dust collection system
  • Compact design that fits on any desk
Makera CARVERA: The Ultimate Desktop CNC Machine for Precision and Versatility
The Makera CARVERA is an advanced, intelligent CNC machine specifically designed for the demands of desktop manufacturing. This compact yet powerful machine combines automation with precision and versatility, making it the ideal choice for designers, engineers, and hobbyists. With innovative features such as automatic leveling, automatic tool changing, integrated dust collection, and an optional 4th axis module, CARVERA sets new standards in the world of CNC machining in a small footprint.
Pack of Smart Features
Auto Tool Changing and Auto Probing
One of CARVERA's standout features is the automatic tool changing system and automatic probing function. Without these automatic features, you would need to manually change each tool during every job and manually perform the probing work, which can be very time-consuming and tedious, especially when machining PCBs or other complex objects. Whether leveling, cutting, cleaning, drilling, or engraving, CARVERA seamlessly switches to the right tool for the task at hand, ensuring you get the best possible result. Just focus on your design and let CARVERA do the rest.
Integrated Dust Collection
Conventional desktop CNC machines are usually not equipped with dust collection due to limited space. CARVERA solves this problem with an innovative, fully integrated dust collection system. This ensures that your projects stay clean from start to finish without the need for additional space for external devices.
Integrated Laser Module
Laser engraving is an impressive technology that allows you to leave beautiful patterns and markings on your products. With the integrated 2.5W diode laser module, you can seamlessly switch between CNC and laser functions and engrave a wide variety of materials, including paper, wood, plastic, leather, fabric, and more. This feature greatly expands CARVERA's versatility, allowing you to create both functional and aesthetic projects.
Optional 4th Axis Module
With an additional axis, entirely new possibilities open up. The optional 4th axis module for CARVERA allows you to machine cylindrical objects, double-sided items, and 3D shapes. CARVERA provides true simultaneous 4-axis machining, enabling you to create three-dimensional models that would typically only be possible with 3D printers. You are not limited to plastics; wood, metal, and other materials can also be transformed into impressive, realistic crafts.
Specifications:
  • Travel Range: X: 280mm, Y: 120mm, Z: 60mm
  • Spindle Speed: 30,000 RPM
  • Tool Changer: Automatic 5-tool changer
  • Dust Collection: Integrated dust collection system
  • Material Compatibility: PCB, wood, plastic, aluminum, brass
  • Software: CARVERA CAM software
  • Connectivity: Wi-Fi, USB
  • Dimensions: 550mm x 450mm x 400mm
  • Weight: 35kg
Package Contents:
  • 1x Makera CARVERA CNC Machine
  • 1x Automatic Tool Changer
  • 1x Dust Collection System
  • 1x Wi-Fi Module
  • 1x CARVERA CAM Software License
  • 1x USB Cable
  • 1x Power Cable
The Makera CARVERA is the perfect solution for anyone looking for a powerful yet compact CNC machine that leaves nothing to be desired. With its intelligent features and expandability, CARVERA sets new standards in desktop manufacturing, allowing you to turn your creative ideas into precise and efficient projects. Whether for PCB work, woodworking, or complex 3D objects, CARVERA makes it possible.
Shipping weight: 50,00 kg
Item weight: 35,00 kg
€ 7.140,00
