Makera Spiral 'O' Single Flute Bit - 1/8 Shank
Makera Spiral 'O' Single Flute Bit - 1/8? Shank
  • Shank Diameter: 3.175mm
  • Total Length: 38mm or more
  • Material: Solid Carbide
Product Description:
The Makera Spiral 'O' Single Flute Bit provides excellent chip evacuation, reduces the risk of chip re-cutting, and ensures a clean cut.
Specifications:
  • Shank Diameter: 3.175 mm
  • Total Length: 38 mm or more
Applications:
  • Contour cutting of sheets, plates, and blocks
  • Surface cleaning
  • Pocket milling
  • Hole boring
Materials:
  • Wood
  • Plastics
  • Composite materials
Tool Reference Parameters:
* RPM: Spindle speed (RPM)
* Feed: Feed rate (mm/min)
* PFeed: Plunge feed rate (mm/min)
* DOC: Depth of cut (mm)
Tool Table:
Tools Aluminum Brass Carbon Fiber Copper Hardwood PCB Plastic Softwood
1*3 mm Flat End - - - - RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
1.5*8 mm Flat End - - - - RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
2*12 mm Flat End - - - - RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
2.5*15 mm Flat End - - - - RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 2
3.175*17 mm Flat End - - - - RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 2
3.175*25 mm Flat End - - - - RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 2
3.175*32 mm Flat End - - - - RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 2
3.175*42 mm Flat End - - - - RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 2
Scope of delivery:
  • 1x Makera Spiral 'O' Single Flute Bit - 1/8? Shank, depending on selection
Shipping weight: 0,10 kg
Item weight: 0,10 kg
Größe
from
€ 7,95
  • Available immediately
