Makera TiN Coating Corn Bit - 1/8 Shank 3.175mm * 12mm (10pcs)
Makera TiN Coating Drill Bit - 1/8″ Shank
  • Shank Diameter: 3.175 mm
  • Drill Diameter: 0.2 mm - 3.175 mm
  • Total Length: ~ 38 mm
  • Material: TiN-coated Solid Carbide
The Corn Bit gets its name from the distinctive geometry of its cutting edge, which resembles the rows of kernels on a corn cob. This design facilitates excellent chip removal and allows for efficient cutting and drilling tasks.
Specifications:
  • Material: TiN Coated Solid Carbide
Applications:
This bit is ideal for:
  • PCB milling and cutting
  • Carbon Fiber/Fiber Glass (FR4) milling and cutting
  • Other similar tasks
Suitable Materials:
  • PCB
  • Fiber Glass (FR4)
  • Carbon Fiber
  • Composite Materials
Tool Reference Parameters:
  • RPM: Spindle Speed (RPM)
  • Feed: Feed Rate (mm/min)
  • PFeed: Plunge Feed Rate (mm/min)
  • DOC: Depth of Cut (mm)
Scope of Delivery:
  • 10x Makera Corn Bit - 1/8" Shank (depending on selection)
Shipping weight: 0,50 kg
Item weight: 0,45 kg
Größe
€ 56,95
